View Poll Results: Which lens is sharper at 50mm f/2.8
DA* 16-50 f/2.8 416.00%
DA* 50-135 f/2.8 2184.00%
Voters: 25. You may not vote on this poll
11-25-2009, 09:17 AM   #16
Any old lens such as takuma, m50, a50 will be sharper than zoom lense...
11-25-2009, 11:48 AM   #17
I have all three DA*16-50, DA*50-135 & A 50/1.7
In order of sharpness at 50 mm, this is how I rate it:
1. A 50/1.7
2. DA* 50-135
3. DA* 16-50
Like everybody had said. Prime 50mm will beat a zoom. But you will be surprise to see how sharp the 50-135 is.
Let's put it this way, 2 nights ago I put my K20D on a Giottos 9360 tripod with Giottos head MH1300-657 which is overkill for this setup. I tried to test the sharpness between DA*50-135 and FA 77mm Ltd at f/2.8 f/4 and f/5.6, ISO 100.
The subject is the rattan box across the living room around 20 feet from the camera under a dim tungsten light condition (basically it only got a light from dining room light which is 10 feet away from the right side).
So it's a very very tough condition that is impossible to achieve sharp result handheld.
At f/2.8, the FA 77 slightly sharper than DA* 50-135
at f/4 and f/5.6, I cannot tell the difference.
Don't worry about BF or FF in this test because actually the purpose of that test is to calibrate my FA 77Ltd on my K20D
11-25-2009, 12:16 PM   #18
then again you could take a walk on the wild side and pick any of the 50 f1.2's...my eye is on the Cosina and the Pentax A 50/1.2, but the right deal on any of them and I will likely grab one. And from what I have seen stopped "down" to around f2 they are all pretty danged sharp. Plus there is the fun of f1.2!!!
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/74819-post-you...-1-2-only.html
We now return you to your regularly scheduled topic.
When I do get another SDM zoom, I think it would be the 50-135 over the 16-50 smply because there seems to be a pretty wide margin of other issues with the 16-50 as far as decentering and what have you. But once ya get a good copy, that is a GREAT leetle lens.
11-25-2009, 03:54 PM   #19
My 50-135 is sharper at 2.8 than my 16-50.
12-22-2009, 02:00 PM   #20
roentarre's Avatar
Olympus 50mm f2 macro is a very very sharp lens. On that note, all companies produce 50mm lenses very well and all are very sharp these days. Almost all have bad ugly bokeh regardless how bright they are.
12-22-2009, 02:11 PM   #21
ftpaddict's Avatar
QuoteOriginally posted by roentarre Quote
Shhh, don't tell that to Leica people.
50mm, da*, k-mount, lens, pentax lens, slr lens
50mm 1.7 vs 70mm limited for portraits...is one much sharper than the other? shaolin95 Pentax SLR Lens Discussion 13 04-22-2010 05:05 AM
which lens is sharper? DA 18-55 al II or A 35-105mm f3.5 angelo9978 Pentax SLR Lens Discussion 8 04-09-2010 09:18 AM
OK, Which is Sharper ? wll Pentax SLR Lens Discussion 10 09-06-2009 06:27 PM
What is sharper karq Pentax SLR Lens Discussion 6 10-25-2008 02:17 AM
upgrade/ sharper lens fashionista Pentax SLR Lens Discussion 9 07-28-2008 10:22 PM
All times are GMT -7. The time now is 04:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
