Originally posted by PentaJP I, too, bought my used Tamron F 1.4 Pz-AF MC4 from B&H Photo back in August.
It just cost me $36.45 including shipping.
By the way, does this teleconverter work well with wide-to-normal angle lenses at a small F-number? Mine seems to work fine with DA50-200mm at the tele end, but when used on FA 35 (f2-2.8) or FA 50 (f1.4-2.8), overall image sharpness gets really compromised. It's not that auto focus is wrong. I hope my copy would work flawlessly on DA* 300, which I intend to buy in the future.
Great to hear. Sounds like they come across them semi-frequently.
I haven't used the TC on wider focal lengths and don't know that I would since carrying around mid-size tele prime is just about the same weight as carrying the TC. (FA 35 X 1.4 = 49mm - my DA 40 weighs about 3.2 oz I think and the DA 70 weighs about 4.6 oz.) Were you thinking of a different situation for use of the TC with a wide angle?
It should work well on your DA* 300 - not flawlessly though, as of course you lose the f/stop and the AF is about 2 to 3 times slower than normal (takes a few seconds to zero in).
A note about focusing with the TC ... I disabled the half-press shutter focus feature on my K20D. I've shot this way for quite some time, but it also seems to work well with my new MC4 TC. When using the AF button on the back of the camera to focus, I find that If I press it more than once (with some finessed timing) while it's focusing (lift my finger off, then press again), it seems to lock on to the target a bit quicker than using the default half-press-shutter method.
