To provide an out-of-focus PSF is hard work typically not even done in regular lens tests.
I know of some tests which have published the radial power density distribution of the out-of-focus PSF (a chart which theoretically is the step function). And not
everybody intuitively would expect a Gaussian blur
It could be motivating if you would publish the radial power density distribution chart for the three RGB channels in exchange for the PSF you receive in this thread.
As far as photography is concerned, these are the most relevant parameters in classifying an out-of-focus PSF:
1. relative difference of radii of the 50% PSF value in the RGB channels.
2. momenta of power distribution relative to the step function
1. is responsible for out-of-focus fringing (bokeh fringing or bokeh color aberration where aberration is a non-applicable term in this situation though).
With respect to restoring a linear response curve from JPG or RAW data:
sRGB doesn't follow a gamma curve. The exact formula is more complex and gamma=2.2 is a bad approximation for low luminosities.
Panorama software like PTGui will compute the exact response curve from the overlap of a few images and additionally correct for vignetting and distortion. You may want to use this feature for a calibration of your own measurements.
My contribution is a crop from an club scene shot with a blue power LED in the background. The attachment shows a 100% crop from a 14.6 MP camera at ISO 1600. Lens is a Zeiss 50mm/1.4 shot at f/1.4. Position of the blue disk is at half way between center and left horizontal border. Definitely not intuitvely Gaussian blur
(I know you can't use this shot. But it may entertain other readers of this thread
