11-28-2009, 08:28 PM   #1
SMC Takumar M42 2.5/135 lens on K10D
I have the above lens together with a M42 Pentax adapter for my K10D.
This lens has a moveable slide on the lens body (MAN/AUTO) what setting should this be on to take a shot, how, when & why is this function used.
What is the correct sequence for taking shots
Camera settings & technique steps:
1. MF = On, Mode = M, Focus subject, Set F-stop, set exposure speed value, (shutter release halfcocked) shoot,
2. MF = On, Mode = Av, Focus subject, Set F-stop, exposure speed value autoset by camera, (shutter release halfcocked) shoot,
Both of these techniques appear to work OK giving similar results whether the lens diaphram clutch slide is in the MAN or AUTO position.
What other modes/techniques/settings can I use. ?
On the K10D can/do I use the AV-L or green button for setting exposure settings ?
How,when and why do i need to change the Man/Auto lens setting.,or is it safe to always set on MAN for the K10D for EV and f-stop adjustments, and taking the shot ?
TIA
11-28-2009, 08:57 PM   #2
Nick Siebers's Avatar
The camera does not interface with that lens in the way the "auto" setting requires: the lens will stay wide open if set to auto. In manual, the aperture will close down to the f-stop to which you set the lens as you set it. The viewfinder will grow darker, depth of field will increase.
As for exposure method, 1 or 2 will work. I find when using Av mode I often need to set my exposure compensation to +0.5 to 1.5, but your camera may vary - this is based on looking at the histogram on the results. Good luck!
exposure, f-stop, k-mount, k10d, lens, m42 2.5/135 lens, pentax lens, release, shutter, slr lens, smc takumar m42, subject, value
SMC Takumar 200mm f4 M42 - good lens? kevinfox203 Pentax SLR Lens Discussion 8 09-16-2010 12:11 PM
For Sale - Sold: Asahi Pentax SMC-Takumar 50mm f/4 1:2 Macro M42 Mount Lens wallyb Sold Items 3 07-24-2009 06:48 PM
For Sale - Sold: Asahi Pentax SMC Takumar 50mm f/1.4 M42 Screw Mount Lens wallyb Sold Items 4 12-29-2008 11:18 AM
All times are GMT -7. The time now is 01:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
