A little more information might help.
- What lens are you using?
- How are you determining exposure?
- If an "A" contact lens, is the aperture ring in the "A" position?
- If not an "A" contact lens, are you familiar with the general issues related to stopped-down metering (the only metering available with non-A lenses)?
I own the Katzeye with Optibrite and previously owned the non-Optibrite version. Both meter essentially as well as the stock screen with "A" contact lenses. That is not saying much though since all three screen pretty much suck for stopped-down metering at wider apertures (gross underexposure). That being said, it is unlikely that your screen is at fault. That wretched behavior is a feature of the metering system and is actually addressed in the owner's manual.
As for the viewfinder going dark...that is what you would expect with a variable aperture lens and a proper focusing screen. For example, the 18-55/3.5-5.6 passes less than half as much light at 55mm as it does at 18mm.
