Originally posted by Andrezao Hmm so the brand itself is bad?
Not necessarily; they do't actually make lenses, but rather stick their name on lenses imported from various other sources. The problem isn't the brand, it's the very nature of this type of "simple hollow tube" lens. As I mentioned before, they provide almost all of the disadvantages of mirror lenses, but with more CA and other IQ problems, and are much larger. I really can't imagine any reason why one would choose such a thing over a mirror lens if one is looking for an inexpensive lightweight lens of long focal length.
Quote: So down to it, what would be better a Teleconverter 2x or a 500mm Mirror lens?
A 2X teleconverter causes you too lose 2 stops of light, turning an f/4 lens into f/8, or an f/5.6 into f/11. That plus they usually degrade IQ terribly. Between the two, the mirror lens will generally do better. Not necessarily all *that* much better than simply cropping the results from your 300mm lens, though. there is no free lunch here - if you want really high quality results at longer focal lengths than you currently have, you are going to have to pay for them one way or another. There are quite a few others threads on this forum regarding the various options - usually with the word "wildlife" in them; you might want to check some of those out. The various 400/5.6 lenses are potentially worth considering too.
