12-10-2009, 02:24 PM   #1
philbaum's Avatar
Does teleconverter installation sequence matter?
Seems like i read somewhere that the teleconverter, in my case a Tamron 1.4X, should go on the body before the lens is installed, usuallly my DA300 if that matters.
Does anyone know the basis for that recommendation is? is it the mechanical fit, the AF connection, etc. i don't get why.
I suppose for really heavy lenses, that assembly of converters and lenses to the body is best done in smaller pieces, but a 300mm lens isn't all that heavy, esp at f4. If someone wanted to store their lens and converter assembly together, because it was most often used that way, why would the equipment be affected one way or the other.
thank you,
12-10-2009, 02:44 PM   #2
Eruditass's Avatar
Heh, I originally read this as something completely different.
No, I don't think it really matters (if anything, just weight and mechanical stress in rare cases), just like the M42 adapter.
12-10-2009, 03:26 PM   #3
Ben_Edict's Avatar
I personally always fit the tc to the lens and then mount the complete assembly to the camera. Never had a problem with that apporach.
Ben
12-10-2009, 03:41 PM   #4
GerryL's Avatar
QuoteOriginally posted by Ben_Edict Quote
Ben
This is what I do too.
12-10-2009, 04:07 PM   #5
dadipentak's Avatar
I don't pay any attention to the sequence (whatever seems most convenient at the time) I've had no problems--that I'm aware of.
12-10-2009, 04:29 PM   #6
The manual for my Sigma TC says to mount it to the lens first rather than the camera body, so that's what I've always done. Not that I can imagine how doing it the other way round would cause any problems.
12-10-2009, 05:45 PM   #7
Marc Sabatella's Avatar
Only thing I'd suggest is doing it in such a way that you don't expose the inside of the camera to the air (= dust) longer than necessary. So if you mount the TC to the lens first, do it with your previous lens mounted to your camera. If you are planning to mount the TC to the lens currently on your camera, that would imply mounting the TC to camera first after removing the lens.
12-10-2009, 08:03 PM   #8
dadipentak's Avatar
I agree with this.
12-10-2009, 08:54 PM   #9
FotoPete's Avatar
I think it can also mean to minimize dust/contact with the front end of the TC.
body, k-mount, lens, lenses, pentax lens, slr lens, teleconverter
Sports Motorcycle Crash Sequence jbrowning Post Your Photos! 16 08-02-2010 07:44 PM
Misc A Perpetual Sequence kevinschoenmakers Post Your Photos! 6 04-21-2010 02:10 AM
K200D Sequence alexanderk1987 Troubleshooting and Beginner Help 5 01-28-2010 06:00 AM
a sequence of 3 duck photos little laker Post Your Photos! 1 05-12-2007 04:38 PM
All times are GMT -7. The time now is 07:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
