Originally posted by Ash And ISO was fixed between all the shots? (sorry if this is blooming obvious Gary...)
Outdoor lighting conditions do change quickly depending on the cloud cover too.
Yes ISO was fixed.
Originally posted by Ash The concept I was trying to illustrate though was that those lenses I mentioned produce varying image exposures based on the aperture of the lens, and does this despite the same apparent total exposure settings for each shot. The scenes I'd observed exhibiting this phenomenon weren't subject to varying ambient light intensity as a cloudy sky.
The ambient light wasn't that variable Ash. Also it happened on three separate days and always only when wide open. Under normal shooting conditions it would be a non issue because I wouldn't be trying to attain equivalent exposures and the overexposure is within the realms of PP correction.
You have to remember also that this isn't a metering issue, camera and light meter both agreed, it's the resulting image using the lens wide open that is the anomaly.
Originally posted by Igilligan I think I recall having a similar response with my FA 50 1.4... but my test was not nearly as controlled as yours... but wide open seemed to confuse the camera some.
ps exif is not intact for me.
pss when did you get the fa 35??? and more importantly, when can I borrow it
I got it last year, you can borrow it when you get a camera.
Originally posted by stevebrot Can we see a blank wall series? That is the acid test!
Blank, you sure you don't want bricks Steve?
If I get a chance I'll do it tomorrow, but I'm not that bothered, testing (acid or otherwise) won't change anything and won't affect anyone unless I sell it to a first year photography student.
