12-15-2009, 02:39 PM   #1
DA 15mm Rectilinear?
Hi Folks!
Is the DA 15mm f/4 a rectilinear lens? That is, not a fish eye?
Thanks!
Dave
12-15-2009, 02:42 PM   #2
Yes. That's correct. It's rectilinear.
I was about to buy it, but ran into a DA 12-24mm, and also read one of the reviews that the DA 12-24mm is sharper than the DA 15mm.
So I'll hold off the DA 15mm for a while.
12-15-2009, 02:42 PM   #3
wasser's Avatar
The DA 15mm f4 is a rectilinear lens.
12-15-2009, 03:09 PM   #4
Otis Memorial Pentaxian
Pretty low distortion too.
12-15-2009, 08:26 PM   #5
DA15
QuoteOriginally posted by SOldBear Quote
Arguably so but the DA15 is not soft, has noticeably less CA, and it's much much nicer to carry around all day. (Speaking from experience of both.)
12-15-2009, 08:40 PM   #6
Wheatfield's Avatar
QuoteOriginally posted by timo Quote
Absolutely true. The 12-24 is a horse, and not at all pleasant to use, though it's results are good.
I quite like using and carrying my DA15, and it's results are also good.
12-15-2009, 09:56 PM   #7
roentarre's Avatar
Its distorsion is quite negligible given its small size and boutique metallic build.
12-16-2009, 06:18 AM   #8
i do not think that 12-24 can be sharper than the prime. for the sharpness in the range I would take a 15/4
12-16-2009, 10:12 PM   #9
Pentaxor's Avatar
QuoteOriginally posted by artemapei Quote
it is sharper than the DA14 prime and DA21 prime. the 12-24 lens is an exception to the IQ standard of the zoom lenses. it just performs better than some of the modern UW prime lenses. the DA15 probably is as sharp or a bit sharper than the 12-24 at the center. but the border and corner sharpness is the strongest points of the 12-24, making it more ideal for an UW lens. however, the DA15 has a tiny trace of barrel distortion which would be deemed insignificant or unnoticeable. also the CA control is way much better than the DA12-24.
12-16-2009, 10:42 PM   #10
Marc Sabatella's Avatar
Photozone's numbers have the 15 somewhat sharper in the center at all apertures, and the 12-24 significantly sharper in the borders at f/4 and f/5.6. But even in the borders, the 15 catches up by f/8, which is probably where the lens would be used most often. Considering the 15 always wins by a pretty hefty margin in distortion and CA control, I can't see the point of choosing the 12-24 on QA concerns. Of course, it could still be worth choosing simply because it's much more flexible.
12-17-2009, 09:55 AM   #11
Bought myself a DA15 today, even though I already have the DA12-24.
Planning to use the K-x with the DA15, DA21, Vivitar 28 Close Focus, DA35, Helios-44K-4, and DA70 as a lightweight/small travel kit.
da, da 15mm, k-mount, pentax lens, slr lens
Rectilinear vs fisheye wide angle question PentaxPoke Pentax SLR Lens Discussion 23 09-03-2008 10:45 PM
K200D deserves more attention! A couple of questions (ghosting and rectilinear uw) cheekygeek Pentax DSLR Discussion 3 07-14-2008 06:30 AM
What should be the maximum price for Pentax-A 15mm lens as the DA 15mm is coming up? Mitch34 Pentax SLR Lens Discussion 6 06-24-2008 04:40 PM
Wide angle: rectilinear or fisheye? mikem Pentax SLR Lens Discussion 18 05-24-2008 09:48 PM
new APO Rapid Rectilinear 180mm Nesster Pentax SLR Lens Discussion 1 01-19-2008 03:05 PM
All times are GMT -7. The time now is 10:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
