12-15-2009, 06:00 PM   #1
smigol's Avatar
Troubleshooting SDM lens AF problem
My 16-60 zoom seems to no longer wish to AF with my K10D.
Here are the symptoms:
No AF activity when pressing the AF button or the half-press of the shutter button.
The info screen shows the AF/MF status of the switch on the lens as well as the zoom position, so it appears to be communicating with the body properly.
My 50-135 works fine.
I'm about to go on a 2 week trip tomorrow and I was cleaning my gear when I found this problem. I've tried turning the debug software off and on. I only have one other SDM lens and it works ok. My other DA and D-FA lenses work ok.
Has anyone else experienced this kind of issue before? Am I missing any special troubleshooting steps to do a quick fix?
Thanks in advance!
12-15-2009, 06:10 PM   #2
Do you have a camera that does not support SDM? (Hint: you can load older firmware version on to your K10D).
If yes, attach the 16-50 to that body, and exercise the screw-drive auto focus mechanism for a while (auto focus far then near then far ....). This may 'wake up' the SDM.
If you can't find a body to exercise the screw-drive auto focus mechanism, use a small screw driver to do so by hand.
If I were you, I would not try to fix it now. I would just load the K10D with an older firmware version and deal with the lens when back from the trip.
12-15-2009, 07:31 PM   #3
smigol's Avatar
Thanks for the tip on the firmware downgrade idea. I've rolled back to a version of 1.10. The lens does focus.
I'll try fooling with it some more and seeing if I can go back to the 1.30 version and keep the SDM working.
12-16-2009, 01:50 PM   #4
bc_the_path's Avatar
Smigol;
-I'll try fooling with it some more and seeing if I can go back to the 1.30 version and keep the SDM working.
It has been tried before and it is believed to be impossible.
I suggest you don't spend your precious time...
Good luck, from now on
12-16-2009, 05:54 PM   #5
I had the same problem too
I also had the same problem too with my original 16-50mm. It would work find with screw-drive autofocus, but SDM focus would not work. Ended up sending it back to Pentax and received a new one in the mail about 1 month later.
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/63908-autofocus...00d-super.html
af, button, k-mount, lens, pentax lens, sdm, slr lens
Very strange SDM problem - anyone experience this? Jonska Pentax DSLR Discussion 21 12-02-2010 03:16 PM
50-135mm SDM problem not a myth bng4bk Pentax SLR Lens Discussion 13 10-13-2010 07:56 AM
New Pentax user old SDM problem? gloop Pentax SLR Lens Discussion 11 05-11-2010 08:25 AM
New 55mm SDM 645D lens means no SDM II? alehel Pentax News and Rumors 11 03-14-2010 09:43 AM
Lens offer from Amazon: DA* 50-135 SDM & DA* 16-50 SDM f8 Pentax SLR Lens Discussion 4 03-25-2008 04:45 AM
All times are GMT -7. The time now is 10:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
