Originally posted by artemapei I've seen it on our photomarket today (in China). Do you think it'll keep the infinity for pentax lenses while being used on canon bodies?
most PK-EOS adapters available today permit infinity focus. if the description states the adapter can "infinity focus" it probably does.
there are two types. one mounts the lens on the body in normal position with focus scale on top. the other mounts the lens with focus scale on the side, which moves the rear-protruding part of the lens to the side to prevent interference with the mirror; since some PK lenses protrude to the rear more than others the side mount can permit use of those more protruding that are impossible to mount using the first type of adapter.
PK-EOS adapters are very thin, only 1.5mm, so use of quality material such as brass or a hard alluminum alloy is a plus.
