Originally posted by photogerald Hi Frank, and welcome!
While the DA55-300 is an excellent value for the money, I would not expect it to be in the same league as your Canon 70-200/4L (yes folks, this is the legendary L-series zoom).
That said, there are other alternatives you can also consider. If you want a Pentax kit that would be equivalent to the zoom range and DOF as your 70-200/4L on your FF 5D, then the closest match would be the DA*50-135/2.8 (shooting a subject at 135mm@f2.8 on APS-C should give the same FOV/subject size and DOF as 200mm@f4 on FF, assuming working distance is the same). Another consideration is the Sigma 50-150 HSM. Both of these lenses have been specifically designed to work on APS-C, so they will be lighter and more compact than FF 70-200 zooms.
However, since you mentioned you sometimes need more reach, then you should also consider Tamron and Sigma's 70-200/2.8 offerings. These are also excellent, and on APS-C would be equivalent to 105-300mm on FF (though you will be giving up a bit on the wide end). IMHO, you will get the best bang for your buck with either of these if you can put up with the extra weight.
The DA*60-250/4 is also a top-flight offering, but it is a bit pricier and it is f4 vs. f2.8, however the difference in out-of-focus rendering may not matter that much for your usage. The advantage with this lens over the 70-200's is that you will get even more reach on the long end, as well as a little bit more on the wide end. And like all DA* lenses, it is also weather-sealed.
By the way, the DA L 55-300 is optically the same as the DA version, but with lesser build (ie-plastic lens mount) and doesn't include a hood.
It also goes without saying that with Pentax, all lenses will be stabilized thanks to the in-body SR.
I hope this helps.
Thanks to all of you.
You've given me several choices to consider.
Again, my main goal is to get my equipment bag more in line with my current needs.
I used to shoot a lot but circumstances make that impossible now.
I have a hard time continuing to justify the investment I've got in equipment.
Plus, I'd really like to have less weight to carry when I do get out.
I want a smaller, less expensive kit and simply don't like the feel of the Digital Rebel and found a review on the K-x.
Back to Glass;
I have had some problems with Sigma and Canon compatibility.
Once they re-chipped my lens but, twice they said it couldn't be done so I have 2 Sigma paper weights.
I don't know if the same problem exists in Pentax mount Sigmas but, I have a bad taste for Sigma.
I had one of the, mentioned, Minolta beer can 70-210mm lenses. Rumor had it that it was so good that it was re-badged for Leica.
The Canon is the best lens I have ever owned and one I would surely miss.
I'm going to lurk around here
and read some more before I buy anything.
First, I need to get my new K-x (Friday says Amazon) and see if it fits and handles to my liking.
I just wanted to find out what you guys thought about what was available in that focal length.
Keep the suggestions coming.
Thanks,
Frank
