12-17-2009, 02:40 PM   #1
VincenTC's Avatar
[langtitle=it]DA & D-XENON[/langtitle]
Hi to everyone,
please, what's the difference between DA and D-XENON 50-200?
I have none of two, I read somewhere may it's better the last one in terms of sharpness and 3d feeling.
I've a doubt because I think they share the same optic project, the main difference is the barrel.
Someone knows?
Thanks.
12-17-2009, 03:05 PM   #2
LeDave's Avatar
The D-Xenon 50-200 is made in a Pentax factory and is designed by Pentax to be a DA 50-200 clone, the only difference is the grip and the blue ring.
12-17-2009, 03:23 PM   #3
VincenTC's Avatar
QuoteOriginally posted by LeDave Quote
Thanks!
12-17-2009, 04:18 PM   #4
netuser's Avatar
Also the coating is diferent.
12-17-2009, 06:26 PM   #5
creampuff's Avatar
QuoteOriginally posted by netuser Quote
Not true at all.
I had the Schneider 18-55mm kit lens and the lens coating was identical to the Pentax kit lens. Recently my friends and I compared 2 copies of the Schneider 12-24mm side by side with the DA 12-24mm and the lens coatings were the same.
12-18-2009, 12:39 AM   #6
What about the D-Xenon 100mm F/2.8 ?
Is it the same than Pentax SMC D FA 100mm F/2.8?
I am thinking to buy the Xenon instead of the Pentax, but will it deliver the same IQ?
Thanks
12-18-2009, 03:09 AM   #7
These lenses marketed by Samsung are exact copies of Pentax ones. No difference at all, except minor body alterations and different text. Any question you have for a Pentax lens will have the same answer as one for a Xenon lens. It was just a cooperative marketing venture by Pentax and Samsung.
There is a slight difference in the GX series of cameras, though, versus their Pentax counterparts.
12-18-2009, 06:40 PM   #8
Well, I just order my D-Xenon 100mm F/2.8 Macro, $385 including S&H, from Amazon store, if it is an exact copy of the Pentax version I would be saving a couple of hundreds. The ETA is Dec/28th, so I will let you know how doest it feel and performs.
Regards and Marry Xmas to all the Pentax fans!
12-20-2009, 12:17 AM   #9
DA & D-XENON
QuoteOriginally posted by Bumblebee71 Quote
My D-Xenon 100 mm F/2.8 macro seems less sharp than DA 100 mm F/2.8 as some Pentaxian in this forum said. I am anxious to hear your test shot on D-Xenon 100 mm Macro.
12-20-2009, 01:43 AM   #10
Its called badge engineering.
12-21-2009, 03:11 PM   #11
The Xenon lens hoods don't have the removable filter window slide in section.
12-22-2009, 04:44 AM   #12
sajah's Avatar
Really? I have D-Xenon 18-55mm and its hood does have a removable window where you can adjust polarizer without removing the hood.
On the other hand, I have D-Xenon 12-24mm and the hood doesn't have such thing. I've never seen a Pentax DA 12-24mm before, does its hood have the window?
12-22-2009, 04:50 AM   #13
wwwmorrell's Avatar
QuoteOriginally posted by Richard Day Quote
Neither does the Pentax DA 12-24mm, well my lens anyway.
d-xenon, da, k-mount, pentax lens, slr lens
Macro Premières photos avec mon K-7 YOYO31 Post Your Photos! 6 11-28-2010 05:35 AM
Landscape La pêche à Bonnieu loule Photo Critique 3 10-02-2010 12:23 AM
Problème avec K-X et molette de sélection Tapirashabrack Pentax DSLR Discussion 3 09-19-2010 12:54 AM
All times are GMT -7. The time now is 10:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
