12-20-2009, 12:18 AM   #16
Canada_Rockies's Avatar
I just ordered mine used for C$30.00.
I tried for several genuine Pentax mount adaptors, and someone was always in the auction with those last minute automatic bids. I didn't want to pay more than $30 + shipping, so I finally smartened up and e-mailed my friend Tim at Vintage Visuals Photographic in Calgary saying I wanted a genuine Pentax Mount adaptor K. He e-mailed back a few minutes later and said he had one for $30. I sent him the CC on the secure order page.
I need one because I have, in the last couple of months, come into a Fujica ST-901 with 50/1.4 and off brand 2x converter. More recently a Spotmatic F with SMC Takumar 55/1.8 and an off brand 85-210 arrived in a nice leather camera case. Both were free. For C$30 I get not one but two fast 50's or thereabouts to use on the K10, MZ-S and/or SF-1. Gloat.
12-20-2009, 03:06 AM   #17
LightBug's Avatar
I would recommend the genuine adapter as well. The genuine adapter is very easy to install and dismount by one's fingers. The off-brand may need some tool. I have a few off-brand ones that I try never to use. "Pay more first, hurt only once"
12-20-2009, 05:59 AM   #18
reeftool's Avatar
I use the one from Pentax. It's 30 dollars well spent.
12-20-2009, 06:00 AM   #19
QuoteOriginally posted by jeremyhall Quote
Agree. I compromised and bought this :
M42 to Pentax k10D k100D K200D K20D DL adapter(silver) - eBay, Other Accessories, Photographic Accessories, Cameras. (end time 26-Dec-09 19:06:30 AEDST)
I only plan to use M42 lenses occasionally, and just for mucking around - so not gonna drop 7x the price on a pentax adapter.
Take care with your new adapter. I had one similar to yours (bought retail from Adorama) and almost came to grief the first time it was mounted to my camera. When time came to take it out, I was surprised to find the that it refused to budge. It took several hours of fiddling before I finally got it off. Lesson learned. A few other things I noted before I sent it back:
  • Quality of manufacture was below that of the Pentax version (thinner metal, rougher machining)
  • The adapter was covered with fine metal shards that fell onto the mirror and into the camera
  • The adapter fit poorly inside the camera such that it over-rotated within the mount. This was likely the cause of the jam.
Some forum members have had good luck by removing the adapter's spring, permanently attaching the adapter to the lens, and notching/drilling the lens base to engage the release pin on the K-mount body.
Another member had good luck re-contouring part of the adapter bayonet. With any luck, he will weigh in with some advice on this thread.
Good luck.
(Has two genuine Pentax adapters...not buying the brand-X again)
12-20-2009, 06:05 AM   #20
QuoteOriginally posted by ftpaddict Quote
35 euros for a piece of mass-produced machined steel is a bit steep. IMO.
35 Euros will seem cheap the first time the adapter gets stuck on the camera, regardless of the method of manufacture.
01-22-2010, 03:56 AM   #21
You're prescient.
Bought a US$10 adapter (the one without a flange, that looks like the proper pentax one)... now it's stuck on my old K100D. It's not so bad having a M42 mount camera.. but any ideas about how to un-stick it would be nice.
01-22-2010, 04:14 AM   #22
Lloydy's Avatar
I've had the adaptors from SRB Griturn and found them to be decent quality and price. They are 15 Euro's at the moment.
M42 lenses on Pentax K
Mine have all come with the removal tool, and the tiny locating spring is held in place with a screw rather than a rivet so it can easily be removed and stuck on a lens with a bit of Loctite.
Good service as well.
01-22-2010, 06:15 AM   #23
Lowell Goudge's Avatar
I bought a real one at a local store that specializes in used equipment
I also bought 5 flanged adaptors at $5 each off e-bay to convert non pentax mount lenses to pentax.
So far I have successfully converted a 24F2 and a 28F2 from Nikon AI and Minolta MD to K mount, I have 3 more adaptors to find lenses for
01-22-2010, 10:52 AM   #24
Lloydy's Avatar
So far I have successfully converted a 24F2 and a 28F2 from Nikon AI and Minolta MD to K mount, I have 3 more adaptors to find lenses for:D
Have you looked through the SRB Griturn site? they have a good range of adaptors.
01-22-2010, 11:24 AM   #25
QuoteOriginally posted by Lloydy Quote
I looked but they only , for pentax, offer screw mount adaptors,
the issue is, pentax, and also nikon, have relatively large registry distances (nikon being even longer than pentax). Also no two makers of bayonette lenses use the same distance,
as a result, unless you have a lens with a much shorter registry distance, typically more than 5mm less, the only way to make an adaptor is to either physically change mounts, or to add an optically corrected adaptro in between, This turns out to be a 1.25X teleconverter (I have one nikon to pentax).
that might be fine for a tele lens, but not for wide angle.
01-23-2010, 12:49 AM   #26
hinman's Avatar
I always recommend the Genuine Pentax Adapter from Pentax webstore:
And you can reference my blog posts about m42 adapter
Thanks,
Hin
01-23-2010, 10:38 AM   #27
I recently received my genuine Pentax adaptor from one of our members. The advantages of the Pentax genuine version are that the registration distance is perfect, and the adapter is easily removed with a pen tip (recommended by Pentax) or in my normal operation mode, a fingernail.
01-23-2010, 12:26 PM   #28
sterretje's Avatar
It's cheap, very very cheap. The original Pentax goes here at the moment for around US$90 (taking the average currency ratio, not exchange rate, for pentax cameras/lenses).
I eventually did buy it because I could get a very good deal on a lensand at the end still save money.
01-24-2010, 07:29 AM   #29
ramseybuckeye's Avatar
The Pentax store is always "out of stock" when I look. I got one on Ebay shipped for $35.95 US, it works perfectly and is very easy to install and remove. There are nearly always a few on Ebay, but you have to search. I search with terms like Asahi and Genuine, but a lot of sellers know this so they will throw those words into the listing. Make sure you look at the photo and know what you are looking for.
01-25-2010, 04:14 PM   #30
They were in stock at the Pentax store a few months ago. I wish I'd bought one then.
My current options are hoping I don't get outbid again on the more reasonably-priced ones on eBay, or biting the bullet and paying $46 to the one seller who has a large stock.
adapters, ebay, focus, k-mount, m42, pentax lens, slr lens
m42 to K adapters - what's best *after* Pentax? germar Pentax Camera and Field Accessories 36 04-18-2012 07:39 AM
M42 Screwmount Adapters jaieger Pentax Camera and Field Accessories 29 09-02-2010 01:11 AM
M42 adapters sterretje Pentax SLR Lens Discussion 12 02-08-2009 04:01 PM
M42 Adapters doc58bc Pentax SLR Lens Discussion 5 02-07-2009 06:19 PM
M42 adapters PollitowuzHere Pentax SLR Lens Discussion 14 07-23-2008 12:42 PM
All times are GMT -7. The time now is 08:27 PM. | See also: NikonForums.com, part of our network of photo forums!
