Originally posted by Lloydy Have you looked through the SRB Griturn site? they have a good range of adaptors.
I looked but they only , for pentax, offer screw mount adaptors,
the issue is, pentax, and also nikon, have relatively large registry distances (nikon being even longer than pentax). Also no two makers of bayonette lenses use the same distance,
as a result, unless you have a lens with a much shorter registry distance, typically more than 5mm less, the only way to make an adaptor is to either physically change mounts, or to add an optically corrected adaptro in between, This turns out to be a 1.25X teleconverter (I have one nikon to pentax).
that might be fine for a tele lens, but not for wide angle.
