12-21-2009, 01:31 AM   #1
PENTAX -M f 1:2/ 50mm smc LENS
Could someone let me know what they think of this lens: PENTAX -M f 1:2/ 50mm smc LENS
I know very little about it. I'm thinking about bidding on it on eBay. Apparently it's in very good nick.
I've googled the lens type but there seems to be no exact match (that I've found!) - but fortunately I've stumbled across this forum.
Thanks in advance
Chris
12-21-2009, 01:33 AM   #2
look there: Pentax Lens Review and Specification Database - 50mm F2
12-21-2009, 04:31 AM   #3
pschlute's Avatar
It was sold as the standard lens with many Pentax film cameras in the 1980's
Optically it is a fine lens, but it is the slowest of the 50mm "normal" lenses and for that reason does not command a high price. I paid less than £10 for mine.
The more popular 50mm lens of the M series was the f1.7 I got mine with my first Pentax camera, an MX in 1980 ! The 1.7 will cost more..£25/35 I think, and the fastest M , the 1.4 will be even more .
Do an ebay completed listings search before you buy to check prices.
12-21-2009, 04:42 AM   #4
Transit's Avatar
It is a very compact lens. Stopped down it's fine
Pete
12-21-2009, 12:32 PM   #5
Marc Sabatella's Avatar
Also because it is quite a bit noticeably softer than any of the other 50's at apertures below f/4 or so. And because it is so common - supply & demand keep the price low. $10 is overpaying, given that $20 will usually get you the *much* better M50/1.7.
As for finding info on a lens, it occurs to me the problem is that people don't know which terms in the name of the lens are significant. The relevant ones here are "M" (which says that it is manual focus, manual aperture, and part of the "M" series of relatively small/lightweight mostly metal lenses), the focal length 50mm, and the maximum aperture "1:2" (usually given as f/2, or in combination with the focal length as 50/2). So basically, any lenses you see described as M 50 f/2, M50/2, Pentax M 50/2, or anything like that - they're all talking about this same lens.
12-21-2009, 03:06 PM   #6
jpzk's Avatar
Marc,
What are your thoughts on the SMC A 50mm f/1.2 Lens ?
JP
12-21-2009, 03:21 PM   #7
Go for the M50/1.7 instead. Probably the sharpest of the Pentax 50 primes.
12-22-2009, 03:42 AM   #8
Barnster's Avatar
I have two of these 50's,and they aren't bad for the price.like Marc said,the 501.7 is a much better lens and if your lucky to find a f1.4,i think it's even better.But getting back to the 1.2,it's a good lens for the price.It shouldn't dissapoint you too much.
12-22-2009, 11:32 AM   #9
I've never used any of the f/1.2 lenses. They strike me as speciality items for people who value shallow DOF over virtually all else, and I'm not one of them.
12-23-2009, 07:54 PM   #10
kuuan's Avatar
I believe the f2/50 M Pentax is underrated, it is a fine lens!
12-23-2009, 10:01 PM   #11
Pentaxor's Avatar
QuoteOriginally posted by kuuan Quote
it is a fine lens at f8. being an 50/f2 lens with a subpar performance at wider openings makes it a huge disappointment. compare it with the K50/1.8 or K55/2, and you would obviously see what sealed it's poor reputation.
addition:
but if you like a softish-effect on your image from wide open til f5.6 (much brighter/evident and softest at f2), this lens might appeal you in a certain way.
12-23-2009, 10:12 PM   #12
Pentaxor's Avatar
QuoteOriginally posted by jpzk Quote
Marc,
JP
here are my thoughts on the SMC A 50/1.2
hope this helps !
50mm, k-mount, lens, pentax, pentax lens, slr lens, smc
For Sale - Sold: SMC Pentax-M 50mm f1.7 lens (US) NeverSatisfied Sold Items 6 07-07-2010 04:21 PM
For Sale - Sold: [US] SMC Pentax-M 2.8 28mm Lens, SMC Pentax-A 1.7 50mm soundview Sold Items 4 02-15-2010 02:39 PM
For Sale - Sold: Pentax SMC FA 50mm f/1.4 lens Clem Nichols Sold Items 0 11-11-2009 07:42 PM
Pentax 1:2.0 50mm smc-M lens Jesus Pentax SLR Lens Discussion 4 01-18-2009 04:09 PM
SMC Pentax FA 50mm F1.4 lens Wolf74 Pentax SLR Lens Discussion 3 04-07-2008 02:10 PM
All times are GMT -7. The time now is 10:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
