View Poll Results: Which is better (image & construction) - FA or F - if the mm and -stop are the same?
FA is better. 1076.92%
F is better. 323.08%
Voters: 13. You may not vote on this poll
12-22-2009, 02:12 AM   #1
FA vs. F? What's the difference?
What is the image quality and construction, etc. differences between the FA and the F?
They seem so close, but I can't tell or find any tech info. Is one more plastic? Is one made better? Does one have better images?
Is one generally better than the other if the mm and -stop are the same?
12-22-2009, 03:13 AM   #2
LeDave's Avatar
I think F is discontinued with the FA replacing it. Some say there are some F lenses out there that are better than it's FA counterpart. But both F and FA counterparts should be optically the same with different build looks. I think the FA has some changes in it's electronic parts which has somehow improved it in a way.
12-22-2009, 11:36 AM   #3
Marc Sabatella's Avatar
This site:
Welcome to Bojidar Dimitrov's Pentax K-Mount Page
contains pretty much all the information you'd want to know on pretty much all Pentax K-mount lenses. By checking the optical foruma of any given lenses, iIt will give you a pretty good idea which are optically the same and which are different. As with most things in life, I'd guess that in the cases where there is any optical difference at all, you'll get opinions all over the map on which is better. Some lenses might generate more agreement than others, but it could easily go both ways - eg, the 39/2.3 is better in the F version than the FA version, but the 25/6.4 is better n the FA version (obviously, I made those up). The FA lenses do indeed have a chip that transmits additional info to the camera above and beyond the aperture info and whatever else the F lenses might transmit.
12-23-2009, 08:37 AM   #4
axl
QuoteOriginally posted by LeDave Quote
not all Fs share the optics with FAs. An exanple is 28. F is the same as A optiicaly but FA is new dsign...
Have a look on the page Marc posted link to. You'll see which are different and which are not.
BR
Peter
fa, k-mount, pentax lens, slr lens
IQ difference between FA and A 50mm/1.4? kpp80202 Pentax SLR Lens Discussion 12 11-27-2010 07:19 AM
What's the difference Dxn2 Troubleshooting and Beginner Help 6 12-26-2009 06:55 PM
the difference between BARCUD Pentax SLR Lens Discussion 5 07-26-2008 01:11 AM
K and A difference JCSullivan Pentax SLR Lens Discussion 15 03-04-2008 01:02 AM
What's the difference between ... kjao Pentax Camera and Field Accessories 12 06-17-2007 08:57 AM
All times are GMT -7. The time now is 02:49 AM. | See also: NikonForums.com, part of our network of photo forums!
