12-24-2009, 03:58 PM   #16
Lowell Goudge's Avatar
in the nikon kit I my mother used to use there was a "soft filter"
It is a piece of optical glass with a 15mm hole in the middle that you smear with vasoline to make the outside blurry.
I'll bet it was a lot cheaper than a soft focus 85mm
12-24-2009, 08:29 PM   #17
Wheatfield's Avatar
It was.
My favourite soft filter is a piece of nylon stocking material stretched over a filter ring with some holes burned in with a lit cigarette.
And cheaper still.
But not a soft focus lens, either.
12-24-2009, 11:55 PM   #18
Abbazz's Avatar
Cheaper yes, but using a filter smeared with grease instead of a proper soft focus lens is like using a $50 plastic toy telescope to capture wildlife: with a lot of perseverance and on a bright day, one might be able to get a few acceptable pictures out of the plastic lens, but there is no doubt that the pictures would have been much better while requiring less effort by using a real telephoto lens in the first place!
Cheers!
Abbazz
12-25-2009, 12:51 AM   #19
Pentaxor's Avatar
true we can use some cheap alternatives. the question is are we willing enough to use these in public? I'm pretty sure that majority of people will prefer something that doesn't look ridiculous enough as opposed to using a cheap alternative. such things can be true also with diffusers, DIY macro ring flash, etc....etc....
soft filters are ok, but I don't believe it can really replicate exactly the same image that a real soft lens produces.
12-25-2009, 01:34 AM   #20
On a related aside, you can achieve a soft focus effect by removing select element groups in certain lenses. I've never performed the surgery to anything myself, though.
12-25-2009, 01:49 AM   #21
keyser's Avatar
You know, if you cared more about what people thought of your equipment then the end result, you probably wouldn't be using a Pentax :P
To hell with them, I say! Vaseline your filters
12-25-2009, 01:54 AM   #22
Pentaxor's Avatar
QuoteOriginally posted by wallyb Quote
or just use the soft filter effect camera feature.
12-25-2009, 02:01 AM   #23
QuoteOriginally posted by Pentaxor Quote
As outlined in this thread, there is a significant difference in the image result between something with a physical difference in the lens, and a digital filter.
12-25-2009, 05:13 AM   #24
Ben_Edict's Avatar
exactly.
The only filters, that approach a lens-based soft effect are the Zeiss Softar filters (also sold by B+W and Heliopan directly). They work with small lenses etched and polished into the filter glass, so giving a result quite comparable to a soft focus lens. But their prices also approach that of a secondhand soft focus lens, if you can get them at all.
Ben
12-25-2009, 09:49 AM   #25
Wheatfield's Avatar
QuoteOriginally posted by Ben_Edict Quote
exactly.
Ben
I have a set of Tiffen Soft F/X filters that are similar to Softars, although they are nowhere near as good. The Softars work by imposing a second, slightly out of focus image onto the in focus image, IIRC.
This can be emulated to a degree by applying Gaussian blur to a layer and then reducing the opacity of the layer to an acceptable level.
12-25-2009, 12:12 PM   #26
Pentaxor's Avatar
that sounds quite a bit of work. for someone who spends a lot of his time in front of the pc, pp work would work just fine.
12-25-2009, 12:41 PM   #27
Wheatfield's Avatar
Which sounds like quite a bit of work?
Screwing on a filter or blurring an adjusting the opacity of a layer?
12-25-2009, 02:42 PM   #28
kristoffon's Avatar
reducing "clarity" in lightroom would appear to do the very same thing.
anyone has a good example of a proper soft focus pic to post? sorry ryan but yours is a macro so doesn't count
searching flickr for "soft focus" is useless only turns up crap
12-25-2009, 04:02 PM   #29
Ben_Edict's Avatar
QuoteOriginally posted by kristoffon Quote
Search for David Hamilton on the web and you find nothing but soft focus images…
Ben
12-25-2009, 05:41 PM   #30
Pentaxor's Avatar
post-process, since having a soft filter nor soft lens wouldn't require you to do post-processing just to achieve that same and similar effect. when I said same, that would mean completely identical.
if the price of a great soft filter isn't that far off from a soft lens, IMO, it would be better to just buy the soft lens. unless you prefer using that nice filter with several lenses of different focal lengths, which is a great idea as well.
focus, focus lenses, k-mount, lenses, pentax, pentax lens, slr lens
The Soft Place: Post Your Soft Focus Images jeffkpotter Mini-Challenges, Games, and Photo Stories 64 04-22-2014 05:39 PM
The Soft Place: Post Your Soft Focus Images jeffkpotter Post Your Photos! 22 04-23-2009 09:04 PM
soft or out of focus kiwao Pentax SLR Lens Discussion 13 10-01-2008 02:02 PM
soft focus TheFunk Photographic Technique 2 03-04-2008 10:01 PM
Soft focus lenses, any experience out there? Ole Pentax SLR Lens Discussion 10 06-09-2007 09:48 PM
All times are GMT -7. The time now is 11:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
