06-16-2007, 12:14 PM   #1
ivoire's Avatar
Makinon 2x teleconverter
I found a makinon 2x PK converter in a box of junk. anyone know if it will work on a k10d? or wether it is even worth using?
06-16-2007, 12:45 PM   #2
bottesini's Avatar
It will work as my Vivitar 2x does but you lose autofocus. I assume that it has the contacts for retaining auto aperture unless it's really old. I think these old converters are not that hot optically though so be prepared to lose some quality. If you use it on fast lenses (up to about f3.5) you will retain focus confirmation. Like any lens with no A setting you will have to shoot in manual and set the aperture from the lens and use the green button for metering but they are ok in an emergency.
Carl
06-16-2007, 12:53 PM   #3
ivoire's Avatar
mackinon
looked over the converter, no contacts. must be old, old, old. thanks for the info on how to shoot manually. may give it a try. i've heard that teleconverters as a rule degrade quality.
this converter has no.1.... may be the first of it's kind!
2x, k-mount, makinon, pentax lens, slr lens
PK mount Makinon won't focus to infinity ChildOfVision Pentax SLR Lens Discussion 6 08-16-2009 04:58 PM
Anybody familiar with the Makinon M42 200mm F3.3? Steinback Pentax SLR Lens Discussion 9 04-26-2008 07:27 PM
Makinon 28mm f/2.8 manual deadwolfbones Pentax SLR Lens Discussion 2 10-02-2007 07:23 AM
Makinon 2x teleconverter mediaslinky Pentax SLR Lens Discussion 0 07-05-2007 06:05 PM
All times are GMT -7. The time now is 09:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
