12-24-2009, 02:36 AM   #1
joodiespost's Avatar
Promaster 28-300mm f/3.5-6.3 XR EDO Aspherical Auto Focus Zoom Lens
Its on ebay for 229 buy it now price. Is this a great buy? If so, will this fit on my K-x out of the box?
Thank You
12-24-2009, 08:51 AM   #2
And also, this seems to be a major problem for me as I am new to photography whatsoever. How would I know, in other words what would I look for in a different manufacturers lens to know that it fits the K-x? Obviously, Nikon and Canon APS-C sizes doesn't fit the K-x even though the K-x is an APS-C.
Any help would be appreciated ^^
12-24-2009, 01:57 PM   #3
Eds
Eds's Avatar
Joodie- I have that lens in K mount on a istDS Pentax. Good basic lens giving quite acceptable IQ. Good lens for achieving maximum focal length range at an affordable price. I would say $229 is a fair price as long as it is in good condition. Eds
12-24-2009, 03:07 PM   #4
Thank you Eds for the reply. This might sound dumb but I am a noob. Other than this lens, how would I know if a particular manufacturers lens [other than pentax] with be compatible with my K-x?
12-24-2009, 07:53 PM   #5
msatlas's Avatar
Each brand of camera has its own lens mount. The third-party lens companies (i.e. Tamron, Sigma, Tokina, etc.) make versions of their lenses in each different lens mount. So to get one that works on your K-x you need one that's made in Pentax mount.
The Promaster you've mentioned is actually a Tamron lens re-badged as a Promaster.
Also just a suggestion if you're looking for something to be an all-around lens with a high zoom factor then you may want to consider something that starts at 18mm. This will be a true wide angle on a K-x. Examples:
Tamron 18-200mm f/3.5-6.3 XR Di-II LD Aspherical IF Macro / Promaster 18-200mm f/3.5-6.3 Digital XR EDO Aspherical (these lenses are identical)
Tamron 18-250mm f/3.5-6.3 Di-II LD Aspherical IF Macro / Pentax SMC DA 18-250mm f/3.5-6.3 ED AL [IF] (these lenses are *mostly* identical)
Sigma 18-200mm f/3.5-6.3 DC
Sigma 18-250mm f/3.5-6.3 DC OS HSM
I think the cheapest one is the Tamron/Promaster 18-200. As for whether any of these is a "good buy," well, I'll leave that for someone else.
12-24-2009, 09:22 PM   #6
Marc Sabatella's Avatar
If it says its for Pentax, it fits your camera. It if is a very old manual focus lens and says "M42" or "screwmount" on it, you need an adapter. But otherwise, it works as is. If it's a manual focus focus (will say so in the description), it won't autofocus, of course.
12-24-2009, 11:27 PM   #7
Thank you both for the informative answers. Lens compatibility has always been an irking little stumbling block for me.
Gomawayo ^^ [ty in korean]
12-24-2009, 11:52 PM   #8
Stratman's Avatar
you might want to check the marketplace here for a similar lens, I scored a Sigma 28-200 in pristine condition for $50 or $60 , and for the money, it is not bad at all...
12-25-2009, 12:16 AM   #9
ty, ill keep that in mind
12-25-2009, 01:28 AM   #10
Laurentiu Cristofor's Avatar
QuoteOriginally posted by joodiespost Quote
Well, I think with Pentax, you have the easiest job. You can make some use of any lens that ever worked on a Pentax camera. It's much easier than for Canikon.
Some things to keep in mind are:
- M42 lenses need an adapter - look for either those with preset aperture or with an Auto/Manual switch - ask here for details once you need them
- Old lenses will be manual focus, so keep that in mind if AF is important for you
- Lenses without an A aperture setting are a bit trickier to use - you'll need to use them in M mode and determine the exposure using the green button
When getting lenses of ebay, make sure to check the following:
- no fungus
- no scratches
- aperture and focusing rings move smoothly
- iris blades close fast and don't stick
- auto/manual switch is not stuck
I managed to see fungus, sticky aperture (iris) blades, and a stuck A/M switch, so these issues do come up, especially with older lenses, so it's better to ask the seller in advance.
Hope this helps
12-25-2009, 01:45 AM   #11
thank you for the info, it's so refreshing to know what to look for now with all you guys' help ^^
edit: another question popped up ^^, If i see two lenses that are both 100mm. Priced around the same with more or less similar specs, wouldn't it make more sense to purchase the one with macro functionality over the one without? Or will there be some kind of IQ difference because of the "macro" ability of the other lens? If there is no IQ difference, what would be some of the technical differences be due to one having macro and the other not?
another side question is, would it be okay to purchase a 2x TC for my kit 18-55 lens on the K-x?
Thank you
12-25-2009, 03:10 AM   #12
Two 100mm with same maximum aperture at the same price, and one is macro? I don't think you'll see that. Macro lenses are usually considerably more expensive than a non-macro counterpart.
For the TC - no, it's not worth getting it for your 18-55. There's little point in transforming your kit lens in a 36-110 zoom that is twice as slow - you'll probably lose AF capability too. Get a faster longer zoom instead, especially since a good TC is not really cheap. Look into TCs for extending longer lenses, where the resulting lens would be way more expensive than the price of the additional teleconverter.
12-25-2009, 03:15 AM   #13
QuoteOriginally posted by Laurentiu Cristofor Quote
thank you, so what are some of the differences we will see between a macro and non macro lens with the same focal length? Would one model sacrifice the aperture to become a macro? Any explanation would be appreciated ^^
Thank you
12-25-2009, 03:32 AM   #14
Thank you
The main difference between a macro and non-macro lens of the same aperture and focal length is that the macro lens will focus much closer. Because of this, the glass inside the lens has to be of much higher quality in order to preserve a level of high quality throughout the focusing range (lens defects tend to increase the closer you focus, so you need to start with something of very high quality in the first place). So generally the only "sacrifice" is a cheap price, i.e a dedicated macro lens will be more expensive. In all other ways it usually performs better. But none of this is to say that a non-macro lens will be any kind of disappointment. They're different classes of lenses all together, used for different subjects and purposes.
12-25-2009, 01:08 PM   #15
great, i'm beginning to get a hang of this. I always thought lenses labeled "macro" were for close up shots only. I see that they are even better for other shots, wide or tele than a comparable non-macro lens with similar specs.
28-300mm f/3.5-6.3 xr, auto focus, k-mount, pentax lens, slr lens
For Sale - Sold: Promaster (Tamron manuf.) 17-50mm f/2.8 EDO AF lens for Canon EOS w/ Box! wallyb Sold Items 2 12-15-2009 10:08 PM
For Sale - Sold: Silver Promaster Spectrum 7 100-300mm Macro AF Zoom Lens, Near-new in Box wallyb Sold Items 7 12-14-2009 12:34 AM
Focus problem with Sigma Zoom 28-80mm 1:3.5-5.6 Aspherical AF lens GrahamS Pentax SLR Lens Discussion 4 12-02-2009 05:45 PM
anyone know this lens MC AUTO PROMASTER 300mm f5.6? gratefulbruce Pentax SLR Lens Discussion 0 06-16-2007 09:01 AM
All times are GMT -7. The time now is 09:47 AM. | See also: NikonForums.com, part of our network of photo forums!
