02-07-2010, 07:43 PM   #16
Laurentiu Cristofor's Avatar
Pretty much any lens at f/8.
I wish that were true.
02-07-2010, 07:52 PM   #17
QuoteOriginally posted by Laurentiu Cristofor Quote
With which lenses isn't it?
02-08-2010, 10:52 PM   #18
QuoteOriginally posted by wallyb Quote
There's a difference between a lens being at its sharpest and a lens being sharp.
If you want more specific examples, check this link - you can compare more lenses there. The comparator tool on that site is also very helpful to give an idea about the difference that can be expected between zoom and prime lenses.
02-08-2010, 11:34 PM   #19
Marc Sabatella's Avatar
True, but sharp is a relative term, and the differences are usually pretty small at those apertures. Read the OP's description of the standard of sharpness, and let us know which lenses you think wouldn't fit the bill.
02-09-2010, 12:02 AM   #20
wlachan's Avatar
True, not that everyone cares though. The DA16-45/4 I had was pretty horrible at the long end against the FA43 in any situations. One would think it was sharp until you have seen something so significantly sharper.
02-09-2010, 12:14 AM   #21
PentaxPoke's Avatar
FA35 is one of the sharpest Pentax lenses ever. At f/4 it is sharper than most lenses at f/8. It is even sharper than some Limiteds, and sharper than the Pentax 100mm macros.
Considering the price of the FA35, I can't imagine a lens with a better sharpness/cost ratio.
02-09-2010, 12:32 AM   #22
Jewelltrail's Avatar
EliotK: What lens would produce tack-sharp images for the obsessed pixel-peeper at a reasonable price? (under $500-600?) This is indoor/studio detailed photography but NOT macro, shot from approximately 3-12 ft distance on a tripod.
Thank you.
EliotK:EliotK It is product studio photography, off a tripod, focal distance probably 35-75mm, shot from about 3-10ft, but has to be sharp so that later when customer reviews images they can zoom into parts of image reasonably tight without heavy blur.
Thanks everyone.
Certainly, the primes which have been suggested thus far, which fit between your desired focal range 35-75mm, would all fit the bill. but, if you want some of the freedom which a zoom provides. while still maintaining sharpness, for below your $500 budget, the Tamron 28-75mm would do nicely--I'm sure.
02-09-2010, 02:03 AM   #23
Jimfear's Avatar
QuoteOriginally posted by PentaxPoke Quote
K35/3.5? I have no idea how the FA35 handles compared to the K35 but it sure is a lot more expensive.
02-09-2010, 10:13 AM   #24
What makes you think I didn't? Let's read it together once again:
QuoteOriginally posted by EliotK Quote
"tack-sharp images for the obsessed pixel-peeper" - this sounds like someone willing to split hairs. Kit zooms, for example, wouldn't fit that bill (18-55, 50-200). Of course, your sharpest lens will be the epitome of sharpness until you get to see what a sharper lens can produce.
Also, even if it were true that lenses were undistinguishable at f/8 (which it isn't, and you can get more examples by comparing lenses on the site I pointed to in my previous post), it would be impractical to give away use of wider apertures. Check that Canon 300mm lens at f/2.8 and f/8 and it's amazing how sharp it is even wide open - that is what a sharp lens is about.
02-09-2010, 10:44 AM   #25
My 18-55, for example, while pretty good at F8, was still not nearly as sharp as my sharpest lenses, which have been the Sigma 70 f2.8 macro and the DA 35 f2.8 macro.
02-09-2010, 10:45 AM   #26
And that's the absolute opposite of the OP's other request, "at a reasonable price". We're not saying all lenses are equally sharp at f/8, like there's some sharpness percentage that all lenses achieve. We're saying that around f/8 just about any lens tends to outresolve the sensor. This is true of even the kit lens. However, we're talking strictly about resolution. There are other lens aberrations that may be present no matter how stopped down a lens is, such as coma, CA, LCA, poor contrast/microcontrast, and distortion. This is where more expensive lenses show their chops better than cheaper ones. But as far as having high sharpness, just about any lens will at f8 to f/11 or so.
If the OP wants to make it easy on himself, just get a macro lens like the Sigma 50, 70, Tamron 90, or Pentax 100/3.5. All fairly reasonably priced (usually below $350).
02-09-2010, 10:12 PM   #27
You're making a strawman argument here. I recommended the Nokton for a lens within the OP's budget. The Canon is just an example of what it means for a lens to be tack sharp - I've used that site because it makes it easier to see the differences that can exist between lenses.
The Nokton would be sharper than most non-macro lenses within the OP budget, maybe even sharper than some macros, so all lenses are not equal, even within a budget, even at f/8.
If lenses would usually outresolve sensors, then most of them would be off the chart in their photozone tests (which still use the K10D camera, whose resolution is at the low end today for an SLR). Yet, this does not happen and there's marked difference between them at any aperture you wish to compare.
Not true. Here are some 100% crops from some shots I took at some resolution charts some months ago when I felt like testing lens resolution. They are all shots taken with lenses that are well within the OP budget - the kit lenses and some older primes. Leaving aside the aberrations, the primes look sharper than the zooms, even at f/8. The prime shots even manage to capture the paper texture, which is pretty much lost in the zoom shots.
Dead-center, you're right, the difference is much smaller, but just move a bit from the center - not really border territory, and the difference becomes way more visible. These crops are from the center of the left half of the frame. Hope this helps.
02-10-2010, 12:46 AM   #28
Note that a magenta tint would indicate a slight front focus. Green would indicate back focus.
02-10-2010, 02:17 AM   #29
QuoteOriginally posted by asdf Quote
I know what you're saying, but in this case, I think these show that the focal plane is actually curved.
These are all manual focus shots using LiveView at top magnification for focusing. The tripod was not moved between shots at same focal length, I just took the camera off to exchange lenses. I checked all shots and if they didn't look sharp, I tried a couple more times and I kept the sharpest. Zooms consistently exhibited softness off-center.
For all these shots there is no obvious tint in the center of the frame (which is where I focused on) - the tint starts showing as you look farther away from the center.
DA18-55@40 has some magenta tint towards center - I can't really notice any green.
M40 has a very slight green edge towards exterior, and even harder to notice magenta towards center. Hard to even notice these in that crop.
DA55-200@200 works on reverse - it has green towards interior and magenta towards the exterior of the frame.
K200 is like DA - green interior, magenta exterior
Because the tint is symmetric with respect to the center, I think this is because the focal plane is curved for most of these lenses. The M40 looks the best, but then again - that's a design derived from the Zeiss Tessar.
Here are 100% center crops from the same shots as above:
It's interesting to notice that in the center, the DA50-200 comes up as better than the K200. Otherwise, the M40 is a clear winner. As I said before, the difference is much smaller in the center - it's towards the outside of the shot that softness can be noticed more clearly.
And here is a new set of left and right crops showing the symmetric tint (they correspond to the same lenses as before):
The zooms seem to exhibit a much larger variation in sharpness across the frame.
And for the final bonus, some crops that show that mirror lenses don't have such bad resolution - these are the results I got from the Tokina 500mm - shot from quite a way from the target:
Not bad for resolution and pretty much no aberrations.
02-10-2010, 02:25 AM   #30
Actually, on second thought, I don't think the tint is due to a curved focal plane - must be just CA.
k-mount, lens, pentax lens, slr lens
K-7 video mode and sharpening for pixel-peepers richtrav Pentax DSLR Discussion 0 08-19-2009 12:28 AM
For you pixel peepers... wildman Pentax SLR Lens Discussion 12 01-27-2009 10:33 PM
K200D Noise Performance Chart - Pixel Peepers Rejoice! cputeq Pentax DSLR Discussion 8 06-01-2008 07:04 PM
Wanted! Pixel Peepers - new Sigma 17-70mm superfuzzy Pentax SLR Lens Discussion 9 01-15-2008 07:39 PM
Hay pixel peepers-Help regken Photographic Technique 1 12-02-2007 11:30 AM
All times are GMT -7. The time now is 10:36 AM. | See also: NikonForums.com, part of our network of photo forums!
