12-26-2009, 08:39 PM   #1
DA L 55-300mm lens hood question
Has anyone with the DA L 55-300mm telephoto used a three stage rubber lens hood (58mm) and had any luck with it? With the absence of non-Pentax 58mm tele lens hoods for 55-300mm lenses, and not being able to afford the Pentax version, I am looking for a suitable replacement. How about the 75-300mm lens hoods made for Canons, etc?
Any information would be appreciated. Thanks!!
12-26-2009, 09:09 PM   #2
JohnBee's Avatar
QuoteOriginally posted by xmen Quote
I've used quite a bit of those hoods with many lenses. Though in most cases I find myself favoring a solid hood instead.
However, the Pentax hoods are really convenient because they take advantage of the quick mount which can be reverse on the lens for storage in a bag whereas the other solutions don't do that. I think we all feel what Pentax has done by selling kit lenses less the hoods only to charge 8x the price of the product after the fact. However, if you asked me, I'd have to admit that it's worth getting it.
12-27-2009, 03:49 PM   #3
Thanks for the info. I received some info several weeks ago from another forum member that suggested using the Pentax PH-RBH 58mm lens hood which is made for the 55mm fixed lens. I think I will try that one first since it is a Pentax hood and it is half the cost of the one made specifically for the 55-300 zoom.
12-27-2009, 06:53 PM   #4
Yeah, that was my suggestion. But please, if you do try that, make sure you get the hood from a place with a good return policy. You don't want to be stuck with a useless lens hood if it doesn't work. Just because two Pentax lenses have the same size bayonet-mount hood doesn't mean they are interchangeable. A good example are the hoods for the DA 17-70mm and the DA* 50-135mm. Both are 67-mm bayonet hoods, but neither hood will fit on the wrong lens. That's because the 67-mm measurement refers to the filter threads, and not necessarily the outer diameter of the lens tube where the hood attaches. In the case of the 17-70 and 50-135, those diameters are a couple millimeters different.
12-27-2009, 09:33 PM   #5
Lens hood 55-300mm question
Great suggestion on the return idea. It would be nice if Pentax would/could give some technical help on issues like this. Since I am new to the forum, does Pentax ever get involved in helping with issues like this? I have searched for individual specifications for the various Pentax lens hoods in order to avoid having to play the return game but have not found any help. Thanks for your time.
01-19-2010, 04:34 PM   #6
Lens hood for 55-300mm DA L
I did purchase a 58mm three-way rubber lens hood from ebay (less than $10 with shipping) and am using it now. So far no complaints. Good quality screw mount. It does not interfere with the lens through the full 55-300 zoom. I might some day get the rigid Pentax one, but for now this is a good fix.
01-19-2010, 05:00 PM   #7
Eruditass's Avatar
Note that these two are the same:
PH-RBH / PH-RBG lens hood (DA* 55, DA 55-300mm)
They are the same FL on the wide end, which is what hoods are made for.
and this one is supposed to be close:
PH-RBF58 (FA J 75-300mm)
75mm on a FF is about 50mm on an APS-C, so it may not be as long as the previous hoods, but shouldn't vignette.
01-19-2010, 06:11 PM   #8
But note my post above...the size of the bayonet part may not be exactly the same even on lenses with the same filter diameter. I would imaging that even having the same minimum focal length is no guarantee of compatibility.
I'm not saying the DA* 55mm hood won't fit...I'm just not swearing that it will.
01-19-2010, 08:17 PM   #9
Eruditass's Avatar
QuoteOriginally posted by aerodave Quote
Someone who had both a DA* 55mm and a non-L DA 55-300mm already verified that they are interchangable. Unfortunately, its no longer being sold by BH so if anyone finds out a place that is selling it...
And as said I'm not sure about the FA J.
01-21-2010, 09:59 PM   #10
Thank you all for the info. I just got a note from B&H that they now have the Pentax hood in stock again.
01-22-2010, 06:31 AM   #11
audiobomber's Avatar
Another example, the FA 35mm 2.0 hood doesn't fit on the FA 50mm 1.4, even though they're the same series, the same filter size, and you have to look twice to see which is in your hand. A single 49mm rubber hood fits all my primes (28mm, 35mm, 50mm and 100mm), so that's all I carry.
While I agree with most of what you said, I do have complaints. IMO the 3-stage rubber hood looks plain ugly on the 55-300. It's too wide & flat, and it squashes the bottom of the hood when you put the camera down, even with the largish K20D. More importantly the rubber hood doesn't extend nearly as far as the original hood, making it less effective. I do like that it allows me to access a CPL, and even though the rubber hood is large, it takes very little room in the bag when folded.
I'd like a better solution than the Pentax hood, hopefully at a cheaper price. The 3-stage rubber hood is only partly successful so I'm still looking.
Yeah, but the price is still an ouch for an unsophisticated, fragile plastic tube that can't cost more than 98 cents to make.
04-25-2010, 08:37 AM   #12
islandmahn's Avatar
Rubber lens hood
Hi, for lack of space in my camera bag, I opted for a rubber lens hood. So far, I have had no "bad"experience with it. The good thing is that is already on my lens for a quick change of lenses. If I get a different carry bag that will accomdate the hard lens hood, then I might think of changing.
05-02-2010, 02:48 PM   #13
MegaPower's Avatar
anyone tired the Pentax PH-RBB58 Bayonet Mount Lens Hood for FA 200mm f/4 Lens??
same 58 mm, longer than PH-RBH and PH-RBG.
if I am using the lens mainly in 300mm range under sunlight, should I get the longer hood?
05-02-2010, 04:51 PM   #14
SpecialK's Avatar
I would prefer a hard hood rather than a rubber hood as it may provide a bit more protection from knocks and scrapes.
Plus, if you use a polarizer filter, the hard Pentax hood has the little filter-turning window.
05-02-2010, 06:58 PM   #15
Eruditass's Avatar
QuoteOriginally posted by MegaPower Quote
If you don't mind vignetting at lower FL or taking off the hood, sure
55-300mm, 58mm, da, da l 55-300mm, hood, hoods, k-mount, lens, pentax lens, slr lens
Lens hood question? NecroticSoldier Pentax SLR Lens Discussion 5 04-08-2010 12:55 PM
Lens Hood Question Garyleed Pentax SLR Lens Discussion 1 12-14-2009 09:51 PM
Pentax FAJ 75-300mm is there a lens hood? cb750r Pentax SLR Lens Discussion 2 11-01-2009 11:49 PM
Pentax 55-300mm - lens hood short? gemini Pentax SLR Lens Discussion 9 03-12-2009 01:30 AM
Lens Hood question johngs Troubleshooting and Beginner Help 8 02-05-2009 09:22 AM
All times are GMT -7. The time now is 02:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
