01-01-2010, 03:46 AM   #1
summonbaka's Avatar
[Confirmed: A Pentax K 85mm soft] Weird "pentax lens"...
I saw this while searching for some bargains:
auctions.yahoo.co.jp/jp/auction/v64486498
The images look normal, but there haven't been a soft focus lens for some time and this one does not have a aperture ring.
I think it is fake, can anyone give some clarification?
01-01-2010, 03:48 AM   #2
K 85/2.2 Soft
01-01-2010, 03:50 AM   #3
Steinback's Avatar
Looks like a K 85mm f/2.2 to me.
Pentax Lens Review and Specification Database - 85mm F2.2 Soft
K 85/2.2 Soft
01-01-2010, 04:39 AM   #4
summonbaka's Avatar
So it's a K? That's why i didn't find it on the reviews... didn't search there.
(Where is the aperture ring, is it the upper part with the scale?)
Thanks for the fast replies
P.S. it is still weird. :P
Last edited by summonbaka; 01-01-2010 at 04:42 AM. Reason: I think i understood...
01-01-2010, 07:59 AM   #5
Banned
K 85/2.2 Soft
Not weird, a soft lens was made for the 6x7 Pentax also.
Pentax Lens Review and Specification Database - 120mm F4 Soft
General Description
This is an unusual lens: the images that it produces are quite unique, its aperture range is uncommon, and its appearance does not quite match that of the other Pentax lenses.
The main use of the 85/2.2 Soft is portraiture. Its optical formula is designed so that the image gets softer as the aperture gets wider. In other words, the aperture ring controls the aperture setting and the image sharpness. At f/2.2 the lens is at its softest while at f/5.6 it is already quite sharp. The center of the image is always sharper than the corners. The aperture ring has no click-stops, so the image sharpness can be precisely controlled. The images produced by the 85/2.2 Soft are very pleasing and quite unique, even compared to other soft lenses.
The diaphragm coupling in this lens is fully manual — a desirable feature for a soft lens. The reason is that, due to the connection between aperture and image sharpness, the sharpness of the viewfinder image matches exactly that of the final image. Furthermore, selecting the desired amount of sharpness forces the use of a particular aperture value. In order to achieve proper exposure then, the photographer must change the shutter speed (which may not be possible in all cases).
The lens is reasonably light an compact, and handles quite nicely. It takes a bit of getting used to it, however. The focusing ring is quite narrow and is positioned directly in front of the lens mount while the aperture ring is in front of it. Because of that, bodies with optical aperture read-out will not be able to display the aperture in the viewfinder.
Product Inf
K 85/2.2 Soft
k-mount, pentax lens, slr lens
Do custom "artistic" or even "funny" lens caps evenexist? lovemehate Pentax SLR Lens Discussion 35 02-10-2016 09:10 AM
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
Pentax "A" lens and "F" 1.7X converter on K10d yyyzzz Pentax SLR Lens Discussion 4 07-09-2009 05:04 AM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
At attempt at fake HDR and emulating "The Dave Hill Effect" lastdodobird Post Your Photos! 2 03-05-2008 06:51 PM
All times are GMT -7. The time now is 03:06 AM. | See also: NikonForums.com, part of our network of photo forums!
