01-01-2010, 12:46 PM   #1
seacapt's Avatar
Mamiya DTL 55mm/1.4 Opinions , Compatabillity Issue?
Anybody familliar with this lens , Anything I should know before buying?
01-01-2010, 02:56 PM   #2
georgweb's Avatar
Captain of the Sea, happy new year and I think you will definitely have a winner with this lens.
Here's a pic from it from user Noel, he has posted some more on the same thread, https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/50994-m42-crew-8.html#post822233
Beware, pics from Noel are excellent regardless the lens .-)
From what you are saying you are about to get this lens from a DTL camera:
Source: M42 Mamiya 55_1.4
... and not this lens:
Source: M42 Mamiya SX 55_1.4
AFAIK those two are the same in glass but slightly different in coating. I got the SX and it is a big fave of mine.
With either of these lenses you get the original Carl Zeiss Contarex Planar design from 1959.
Source: Die letzten westdeutschen Kleinbildcameras / Rollei QBM Mouint
The non-SX lens should be straight M42 with an A-M switch and nada mas.
The SX has a protruding pin (file off or just pull out) and a protruding aperture ring (file off) as well as no A-M switch (manual conversion through opening the back).
I'm sure you will have one of the best allround lenses with either of them.
Get it !
Georg
PS: Some more pics from the SX on K100D: Picasa Web Albums - geo
01-01-2010, 03:36 PM   #3
seacapt's Avatar
Thanks Georg, Happy New Year to you as well. Yes it is on a dtl-1000 which I had assumed was M-42 but was confused by info I'd found on the SX lenses.
Was the SX a variation on the K mount?
01-01-2010, 04:01 PM   #4
QuoteOriginally posted by seacapt Quote
The SX had a Mamiya variation on the M42 screw mount. They have the modifications that Georg suggested be filed off. There is more information about them and Mamiya/Sekor 35mm cameras and lenses at:
Mamiya 35mm Cameras by Ron Herron
Ron Herron is the expert on Mamiya 35mm gear.
01-02-2010, 05:02 AM   #5
georgweb's Avatar
Supplementing Steve's link here's one more about those Mamiya M42 cameras: M42 Cameras
Seacapt, if you have a chance to get the information whether the lens you are about to get is SX or not it might be useful for you. As I said the SX is M42 but has some tweaks which make for the tinkerer's joy but the plain user's disgust .-)
01-02-2010, 08:27 AM   #6
noel's Avatar
Yep, the SX has that famous extra pin which you'd want to remove.
In any case, I find that this lens does produce very special bokeh. I definitely would recommend this as a cheaper alternative to say....a planar 50mm or a nokton 58mm.
And thanks George for that kind compliment but it IS indeed the lens that gave it the special bokeh tinge.
Happy new year , everybody
01-02-2010, 05:37 PM   #7
seacapt's Avatar
Thanks for the info. The lens appears to be of the older type. Will post some test shots in M42 Crew thread when it arrives.
01-08-2010, 11:29 AM   #8
seacapt's Avatar
Got the lens , was of the older style so no mods needed and I like it alot! samples being posted in M42 Crew Thread.
Thanks again guys.
k-mount, pentax lens, slr lens
Be the judge; Mamiya-Sekor 55mm 1.4 vs Super-Takumar 50mm 1.4 Yaro Pentax SLR Lens Discussion 5 07-01-2010 10:56 AM
Opinions wanted ;)! 18-55mm and 55-300mm luke0622 Pentax SLR Lens Discussion 2 04-02-2010 06:20 AM
Mamiya / Sekor 55mm f1.8 or SMC Takumar 55mm f1.8? -kb- Pentax SLR Lens Discussion 14 09-16-2009 05:54 AM
All times are GMT -7. The time now is 10:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
