01-07-2010, 11:18 AM   #31
JohnBee's Avatar
QuoteOriginally posted by nottoohairy Quote
...it is great to see all the pics of, and thoughts about 28mm lens bokeh! This is definitely a subjective topic, and it seems there are many factors which influence the out of focus character in photos...
I like the 28mm focal length on my Pentax DSLR because it is a 'normal' focal length. It really is different than using a normal lens on a 35mm camera, as im sure using a normal lens in medium format is, since depth of field at comparable apertures gets narrower as the format size increases...
I have been out taking more pictures with the 28/2 A lens:
That 28/2 is magical!
The only one could find(without looking to hard) was for F mount.
Which raises the question as to how well it would perform under a FF sensor...
01-07-2010, 11:58 AM   #32
blende8's Avatar
QuoteOriginally posted by arpaagent Quote
Just to clarify, the format that a lens is created for does not change the size of the "circle of confusion" at all, it is solely dependent on the focal length, aperture, and distances to the focal point and the background elements.
This is not correct.
Below is a quick comparison between the DA16-50@50 and the FA50/1.4 (both at f2.8):
Same scene, tripod, focussed on something in the foreground, observed the circle in the background.
Originally I noted it first with the DA70, but other DAs show this, too.
Interestingly the DA55 does not show it. This lens covers FF.
01-07-2010, 12:10 PM   #33
Pentaxor's Avatar
QuoteOriginally posted by blende8 Quote
Below is a quick comparison between the DA16-50@50 and the FA50 (both at f2.8):
is this an FA50/2.8 macro or the two other FA50's (1.4 and 1.7) stopped down ?
there is no reason for it to look like that if it's wide open as the blades aren't closed down. did you carefully checked the blades on that particular lens? this is just odd, IMO. FA's are also FF lenses, so the DA55 being a FF could be easily dismissed.
01-07-2010, 12:26 PM   #34
blende8's Avatar
It's the FA50/1.4.
FA's are also FF lenses, so the DA55 being an FF could be easily dismissed.
As I said.
I only noticed this effect on some DA lenses that definitely do not cover FF.
I am no optics expert, but perhaps it has to do with the exit pupil?
01-07-2010, 12:45 PM   #35
arpaagent's Avatar
--image snipped--
Interesting. I also have the DA16-50. I'll do some tests of my own tonight with it against DA50-135, FA50 Macro, F50/1.7, A50/1.2, etc. Maybe I'll also do a test at 24mm against some others. Not that I don't full trust your results but I am certainly curious and would like to see for myself.
01-07-2010, 01:23 PM   #36
Pentaxor's Avatar
It's the FA50/1.4.
As I said.
Yes, that is the most probable reason. COC's shape is influenced by aperture opening.
as far as the DA55 is concerned, I believe it is greatly influenced by it's rounded aperture blades which makes the COC shape consistent in all apertures.
01-07-2010, 02:15 PM   #37
Jimfear's Avatar
To go back to the original purpose of this thread I have dug up two photos taken wide open with two different lenses.
First one is by the K28/3.5, probably the same design as the S-M-C Takumar 28/3.5 above. Pretty good overall but getting a little harsh in the highlights.
Second one is with the Vivitar 28mm f/2 (Kiron made), georgweb had a sample before that looked fine, this one taken at f/2 though and the bokeh going crazy (not to speak of distortion...)
01-07-2010, 04:21 PM   #38
JohnBee's Avatar
QuoteOriginally posted by Jimfear Quote
So same lens(es) but different bokeh's?
01-07-2010, 05:10 PM   #39
gofour3's Avatar
I agree with what Steve said, a 28mm focal length lens would not be my first choice for expecting nice bokeh shots. Try the K50/1.2, it has the nicest that I have seen.
I have the K series 28/2.0 and it is unique as having floating lens elements, which eliminate distortion. Nice bokeh nope, 3D effects on close objects yes.
Phil.
01-07-2010, 05:51 PM   #40
Class A's Avatar
Sigma 28/1.8
These are from my Sigma 28/1.8 (full frame, nine blades, blades never show jaggies like many Pentax lenses). Some Picasa PP but no extra blurring.
Hand-held while it was windy -> not as sharp as it could have been but shows bokeh @ f/3.5.
Attachment 51393
f/3.2:
Attachment 51394
f/5.0:
Attachment 51397
EDIT: I exchanged the original images with others that I sharpened for this small size. They now look a lot more like the originals. The grain in the OOF is from the sharpening but I prefer that to the mushy appearance the previous sharpening method resulted in.
01-07-2010, 06:22 PM   #41
JohnBee's Avatar
The second one looks nice.
1.8 sounds pretty darned impressive for a 28mm too.
How do things look around 2.8?
01-07-2010, 11:15 PM   #42
arpaagent's Avatar
--image snipped--
Please see a post I made in another thread regarding OOF highlights and lens format. I don't want anyone to be misinformed about stuff. Weiland, no offense meant, but I find that your example is misleading. In my tests in the post below, I have shown my setup and explained exactly what I did, so anyone should be able to reproduce my results.
Basically, from my testing, lens format does not affect the OOF highlight sizes.
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/85864-out-focu...tml#post873435
01-08-2010, 11:09 AM   #43
Jimfear's Avatar
QuoteOriginally posted by JohnBee Quote
Same lens, different aperture, different bokeh. Georgweb's photo was stopped down a bit, and the background was also mostly green (and red) which usually produces smother bokeh.
01-08-2010, 03:30 PM   #44
Asahiflex's Avatar
The lens is rare, but here are a few samples made with the SMC Pentax 1:2/28, which is optically the same as the Carl Zeiss 28mm f/2 Distagon 'Hollywood', designed by Erhard Glatzel. The lens features floating elements to provide better results at closer ranges.
01-08-2010, 05:22 PM   #45
gofour3's Avatar
Beautiful shots Peter, that's exactly why I love the K28/2!! You can only appreciate how good this lens is if you own one.
Nice work,
Phil
28mm, 28mm prime lens, bokeh, k-mount, lens, pentax lens, slr lens
Best Prime/Standard Lens for K7 (28mm to 35mm) - (f1.8 to f2.8) brosen Pentax SLR Lens Discussion 74 10-16-2009 02:54 PM
Lens Recommendation (prime) - Bokeh, Indoor, Low Light FckShoes Pentax SLR Lens Discussion 16 12-02-2008 08:06 PM
bokeh of DA*16-50 and DA*50-135 similar to what (prime) lens? Pentaxtic Pentax SLR Lens Discussion 0 12-07-2007 06:21 AM
All times are GMT -7. The time now is 04:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
