Originally posted by Class A Great shots!
You must have been very close for the last one!
Would you like to share what PP you did? Did you sharpen specifically for this output size and what software did you use? I find when I crank up saturation with Picasa, things start to look unnaturally pretty quickly and then prefer a less saturated look but yours seem to be fine. (I don't crank it up in-camera because I don't want to risk individual channels to be blown; I typically don't shoot RAW either since I currently neither have the space for all these megabytes nor the software which would support a good RAW workflow).
Thanks ! I always shoot JPG+RAW. I use orginal JPG for quick browsing and previewing of the pictures but thereafter work with RAW files. Most of these pictures were converted with SilkyPix (I adjust white balance, exposure, ... I usually put saturation value at about 8-10 and sharpness to the normal (default) setting). Then, I used Photoshop Elements 6 for final tweaking (if necessary) and resizing. After resizing to a 1024 pixel width picture, I generally sharpen a bit using Focus Magic (my usual settings are "Blur width" set at 1, "Amount" set at 75%). If I need some noise reduction, I use Noiseware.
Alternatively, some of these pics may have opened in RAW directly with Photoshop Elements. Then I generally use a Saturation setting around 10.
