01-06-2010, 11:39 AM   #1
eccs19's Avatar
105mm Takumar dirt
After giving my 105mm Tak a cleaning, I noticed there is some dirt (or something) on the rear element. I googled to see if I could find info on taking this sucker apart to clean, but didn't have much luck. Anyone have any tips / links on doing this job? I'm hoping I can get just the rear element out without a complete tear down, but I know nothing about doing it.
01-06-2010, 11:46 AM   #2
Lowell Goudge's Avatar
is this on the "outside" of the rear element?
If so, use alcohol to clean the element with a q-tip
01-06-2010, 12:17 PM   #3
eccs19's Avatar
Nope, it's on the inside.
01-06-2010, 12:27 PM   #4
QuoteOriginally posted by eccs19 Quote
too bad
however, I would venture that if yoou look at the rear of the lens, you can see in the photo the rear element retaining ring.
that should let you remove the rear element, you just need the right tool to engage the two slots
my super tak 85 F1.9 appears to be similar in that respect
01-06-2010, 12:30 PM   #5
MattGunn's Avatar
The rear element in this lens is actually a cemented doublet and if the marks to which you refer are a form of lens separation then it will not be possible to repair it (at least without taking out a bank loan). However you can open the lens to check but you will need a spanner wrench or a suitable substitute. This can be used to unscrew the rear element from the back of the lens. The spanner wrench should be engaged in the notch visible in your picture just inside the back of the lens and this should allow you to remove the rear element in its mount as a single unit without opening the rest of the lens. There is a cutaway diagram of this lens here: Die Cast Pro - Super-Multi-Coated Takumar 105mm f/2.8 Index
01-06-2010, 01:40 PM   #6
eccs19's Avatar
Should I take this apart and see if it can be cleaned, or do you think that the dirt that's there shouldn't affect the quality that much? I've not got any before pics from this lens, so it would be hard for me to judge if there is much degradation in the picture. If you think it won't hurt that much, I may just leave it be.
01-06-2010, 01:59 PM   #7
Nesster's Avatar
The best way to see is to take some pictures and see. If there's nothing to bother you and you find the photos good IQ wise, then there's no problem. The 'compared to what could be' is a slippery slope
I would imagine the problems if any show in these conditions - large even surfaces without much detail (i.e. take a pic of the clear northern sky) - the specular highlights in bokeh (i.e. take a pic of lights way out of focus).
For example, on a Tele-Takumar 50/4 I bought cheap and beat up recently:
I believe the stuff inside the light blobs is dust inside the lens, as this is a film shot. For me this is not significant and doesn't affect normal shots to where I would notice. But it's there. If I don't want the dirt in this sort of bokeh I'll just use a different lens.
01-06-2010, 02:06 PM   #8
Hmm... Although your problem is quite different, the remedy still applies:
Brian Ayling's photographic repair tips
Kidding.
105mm, dirt, element, k-mount, pentax lens, slr lens
105mm - Super-Takumar vs DA aesch Pentax SLR Lens Discussion 2 04-04-2009 08:20 PM
For Sale - Sold: Super-Takumar 105mm/2,8 AnttiM Sold Items 3 03-19-2009 11:46 AM
For Sale - Sold: SMC Takumar 105mm/2.8 david.elliott Sold Items 6 03-09-2009 05:53 PM
Takumar 105mm f2.8 just arrived! pt. 1 jamonation Post Your Photos! 1 11-23-2008 01:45 AM
All times are GMT -7. The time now is 05:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
