Originally posted by glasbak Today arrived ths very same sigma macro lens to diagnose/repair for someone.
It suffers from exactly the same problem.
It was easy to repair (if you are a bit technical and have the right equipment)
George, thank you so much! That looks like it describes my problem
exactly, because I have the same marks on the barrel as you show in that picture. I will try this fix soon.
Regarding the tape - did you re-use the tape, or did you use new tape? And if you used new tape, what tape did you use?
With the felt, I'll try to re-use that as well, fixing where it's bunched up, but out of curiosity is there a good source for replacement felt for camera lenses like this?
