01-08-2010, 07:41 AM   #1
artemapei's Avatar
10-17 fisheye: tokina or pentax
Pentax | SMCP-DA 10-17mm f/3.5-4.5 ED Autofocus Lens | 21580
http://www.bhphotovideo.com/c/product/468738-REG/Tokina_ATX107PRODXN_10_17mm...specifications
obviously it's optically the same lens.
pentax cheaper and lighter. which one is better?
01-08-2010, 07:45 AM   #2
RBellavance's Avatar
As you wrote, they are supposed to be optically identical.
But the Tokina is not available in Pentax mount, and the Pentax is not available in Canon or Nikon mount, so you really have no choice if you want to get it
01-08-2010, 07:02 PM   #3
artemapei's Avatar
i c.
the problem is - I have nikon and pentax, and would like to try 10mm fix and 10-17 zoom on each system.
for nikon there are 3 lenses: 10.5mm nikon, 10mm sigma and 10-17 tokina
for pentax - just 2
01-09-2010, 12:14 AM   #4
artemapei's Avatar
there is not only weight difference, there is magnification difference. may be there is some difference in optics?
01-10-2010, 04:28 AM   #5
I think - but do not know for sure, that the only difference between the Tokina and Pentax lenses (10-17, and the 12-24 - note I have both lenses) are (other than the mounts and barrel design):
1) Pentax uses their SMC coatings and Tokina uses their own. Pentax's SMC coatings many years ago were much more advanced (or that was the claim) than the rest. I do not know how true it is any more, but personally - I like the SMC coatings and essentially only have Pentax glass.
2) Pentax uses their focus clutch system and Tokina does not use one. The focus clutch system enables you to use AF and then manually adjust the focus with out switching to manual.
Since you have a Nikon body also, you can make the choice that is most beneficial to you...
also... If I remember correctly, the direction of focus is backwards on Tokina's lenses vs Nikon - I think. I.e., the direction of the twist of the barrel when you go to focus.
k-mount, lens, pentax, pentax lens, slr lens
Fisheye Fever Club -- Flaunt your fisheye photos! troyz Lens Clubs 2943 06-16-2017 01:56 PM
Inexpensive fisheye and semi-fisheye adapters? billiam Pentax Camera and Field Accessories 8 11-09-2010 02:08 PM
DC motor tech from Tokina? Tokina and Pentax relationship? kales Pentax News and Rumors 68 10-14-2010 12:34 PM
For Sale - Sold: Pentax 16-50mm/f2.8, 1.7x adapter, 10-17mm fisheye, Tokina 28-80mm/f2.8 ATX Pr mmzymxf Sold Items 4 05-13-2009 04:54 PM
For Sale - Sold: Tokina 20-35mm f2.8 AT-X Pro, Tokina 28-80mm f2.8 AT-X Pro, Tokina 100-300mm f photobizzz Sold Items 7 01-30-2009 06:04 PM
All times are GMT -7. The time now is 07:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
