01-11-2010, 08:44 AM   #1
Urmas R.'s Avatar
Pentax telephoto lenses reviewed in Colorfoto
May be someone is interested in another set of lab tests on DA* 200mm, DA* 300mm and DA 60-250mm. These were published in a German photography journal Colorfoto. Since they mainly focus on quantifiable aspects of these lenses I put here the links to the resolution charts only.
http://www.colorfoto.de/Testbericht/26554629_3bd61edc71.jpg
http://www.colorfoto.de/Testbericht/26554721_a3db6b98ec.jpg
http://www.colorfoto.de/Testbericht/32593708_0d6a90763d.jpg
http://www.colorfoto.de/Testbericht/32593714_43db929263.jpg
http://www.colorfoto.de/Testbericht/32593720_85efd949d2.jpg
The tests are based on measuring the spatial frequency response or contrast. On the charts you can find how well large or small details could be detected. They shot something like 20 photos of a test chart and took the best into the calculation. Continuous lines show the lens wide open and dotted lines depict the resolution when stopped down by 2 units. Various colors show different part of the image circle, as indicated in the lower right corner. On the right hand side you can find columns with the values for best and worse autofocus accuracy.
01-11-2010, 08:52 AM   #2
QuoteOriginally posted by Urmas R. Quote
Thanks. BTW, it's difficult to compare DA* 200 at the same apertures with the others, since it starts at f/2.8.
01-11-2010, 09:05 AM   #3
Urmas R.'s Avatar
Indeed. Yet, the dotted line in case of the 200mm lens shows it's capabilites when stopped down by two and hence is somewhat comparable to the others. It seems that wide open it is not that good, yet, when stopped down it reaches basically the same resolution figures as the 300mm wide open in the center. The latter one is by far the best in the test, with virtually excellent perfomance even at f4. The zoom lens lags a bit behind the prime lenses and needs to be stopped down to reach similar level of resolution as the others achive wide open.
It is interesting to note that none of these lenses are bothered by the sensor limit (pink line on the far right side of the chart).
charts, colorfoto, da*, k-mount, lenses, lines, pentax lens, resolution, slr lens, tests
400mm plus telephoto lenses - Looking for the thread. jpzk Pentax SLR Lens Discussion 21 02-04-2010 05:23 PM
For Sale - Sold: Two Telephoto Lenses Youngster Sold Items 3 10-12-2009 09:55 AM
Anywhere to rent $$$$$ Pentax telephoto lenses? JHfwp Pentax SLR Lens Discussion 3 07-17-2009 06:12 PM
Seeking advice on telephoto lenses ismaelg Pentax SLR Lens Discussion 15 04-29-2009 08:25 PM
Little iffy on telephoto lenses... steve500 Pentax SLR Lens Discussion 9 01-10-2009 12:24 PM
All times are GMT -7. The time now is 11:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
