Originally posted by Lowell Goudge this is only an observation, but I have always found the M series lenses don't have the same consistancy and feel of K series lenses, mostly the aperture clicks and focusing collar drag just aren't the same,
the impression is that the M series "feel" cheap.
I know it is not scientific but .........
I know from experience that the feel of the aperture ring can be greatly improved by removing it, cleaning any grit or crud, lightly regreasing it and reassembly. I have an S-M-C Takumar 55/2, K55/1.8 and M50/1.7 in front of me right now, and I notice that the M50/1.7 has no shielding to reduce the possibility of dirt getting in there in the first place. The Takumar's distance scale is a separate piece that fits over the gap between aperture ring and lens body. The K55/1.8 has a raised rib on its distance scale that might do the same job but looks less effective.
The M50/1.7 aperture and focusing rings are also thinner, not really a big shock but that does affect how they feel. The M50/2 definitely has a "consumer-grade" feel to it.
Quote: one of the advantages with the M series however, even though I call M series the "mini series" is that most of the lenses use 49mm filters, so you only buy one set and they work on everything. this was done at the expense of speed in the longer lenses.
The 52mm K series always seems a little off to me because of this. Many Takumars also use the 49mm size, and it continues to be used on modern primes.
