01-11-2010, 07:37 PM   #1
DIY: Weather sealing a DA
I'm thinking that it should be possible to add a rubber gasket on the lens mount for weather proofing. This is what the WR's seem to have -- a nice red rubber gasket. Wonder where you can find one off that size?
I'm curious where I can find o-rings and rubber gaskets for a custom size of 57mm.
thanks........
01-11-2010, 08:00 PM   #2
Damn Brit
Guest
A gasket, no matter how thin, will probably affect infinity focusing.
01-11-2010, 08:01 PM   #3
WR adds more than one seal too...
01-11-2010, 08:37 PM   #4
imtheguy's Avatar
Someone needs to pull apart a DA50-200mm just to settle this. Mmmm...maybe it will be me. I am not too pleased with this gift lens so far. More testing tonight.
01-11-2010, 09:06 PM   #5
What do you guys think of this method:
Tech ARP - Weatherproofing Camera Lenses
A wide rubber band seems to do a decent job around the mount.
01-11-2010, 09:16 PM   #6
Damn Brit
Guest
The question has to be asked. How do you plan to test any DIY weather sealing you might come up with?
01-11-2010, 09:27 PM   #7
er1kksen's Avatar
QuoteOriginally posted by Damn Brit Quote
This post made me lol a bit. :-)
The krytox grease thing seems sketchy to me but the rubber band does seem like a rather good, logical idea. If the fit is tight and there are no gaps then it should, in theory, do a decent job of keeping water from entering the lensmount (which has happened to me before with cheaper lenses). Now, Damn Brit raises a fine point about testing being required to declare that theory an actual sound practice, but I don't think any testing is required if it's more of a "just in case" to increase one's peace of mind.
Water can, of course, enter other sections of the lens.
01-11-2010, 11:12 PM   #8
could always silicon it up
gasket, k-mount, pentax lens, rubber, size, slr lens, weather
DIY lens mount sealing krypticide Pentax DSLR Discussion 26 03-04-2018 01:40 AM
weather sealing houstonmacgregor Pentax SLR Lens Discussion 3 07-02-2010 03:00 PM
Weather Sealing... Snowvent Troubleshooting and Beginner Help 17 01-11-2010 04:22 PM
Weather Sealing... rkt Pentax SLR Lens Discussion 2 10-24-2009 05:10 AM
non-weather sealing lens annod Pentax SLR Lens Discussion 4 01-18-2009 04:25 AM
All times are GMT -7. The time now is 10:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
