Originally posted by summonbaka Recently I got into a LBA and bought myself a couple of takumar including the 200 f/4, 55 f/1.8, and 28 f/3.5. The 55mm had some fungus so i got it in quarantine and far away from any other lens, but today i received the 200mm with the metal screw hood for it. And I saw that it may be able to fit the 55mm inside.
I tried and it fitted perfectly through the end of the hood without going too deep. So I gave it a try and fitted it with some bubble-wrap that came with the lens. i put the hood on and the 55mm reversed inside it.
Turns out it works perfectly. Not only that but you can also focus about 2cm in a long throw with the 200mm to do selective focusing, perfect for focus stacking.
Excited i tried the 28mm and also fits nicely but is horribly dark. It may be dark, but the magnification goes to almost 3.5:1.
With both the 55mm and the 28mm i got a working space of about 3cm, and the lenses are still inside the hood for "some protection". I suppose that this can be repeated with some 49mm and 52mm threaded lenses, havent tried any others.
Will post some photos later.
Originally posted by smc Very cool...I've never thought of trying it without a reversing adapter.... looking forwrad to seeing some pics.
Originally posted by Mechan1k
Sorry for keeping you waiting, here are the pics.
The three lenses used for the first tryouts.
The lens inserted on the hood, backwards.
The lenses ready for using
Some rulers, ISO800, wide open(both):
And lastly, the A in Asahi. from the bottom edges there are 5mm:
More pictures here:
PentaxForums.com - summonbaka's Album: [Macro] Takumar modular 2+:1 Macro (200mm+55mm/28mm)
