01-16-2010, 09:58 AM   #1
rustynail925's Avatar
Will the DA 55-300mm be enough for shooting birds
The DA L 50-200mm @ 200mm is just to short for shooting birds. Will the DA 55-300mm be enough?
heres a sample photo @ 200mm resized no crop
How much is the difference of 100mm be? what will it look like if the shot was taken at 300mm?
01-16-2010, 10:00 AM   #2
QuoteOriginally posted by rustynail925 Quote
It may not be enough if you don't camouflage yourself. I like DA* 300 f/4, because the images are sharp enough to be cropped.
All About Birds : Blending into the background
01-16-2010, 10:13 AM   #3
For me 300mm is too short. I'll buy (when?) 150-500mm
01-16-2010, 10:21 AM   #4
Lowell Goudge's Avatar
I started shooting birds on digital with a sigma APO 70-200 F2.8 EX and a 1.4x TC.
300mm is OK for some things, large herons etc, and BIF because it is hard to get closer track and focus and frame all at the same time.
I shoot now days with one of 2 combos for smaller birds or less approchable birds,
the same Sigma APO 70-200 F2.8 ex and a 2x Sigma TC or an SMC 300mmF4 and Pentax SMC-F 1.7x AF TC (500mm F6.7 equivelent).
I also use flash with both combos, *istD and TTL flash with the 300F4 and TC and any of my bodies and P-TTL flash with the Sigma.
01-16-2010, 10:23 AM   #5
QuoteOriginally posted by MariusCTM Quote
That will be to heavy to carry and shoot handeld. the lighter the better
01-16-2010, 10:23 AM   #6
300mm would be 50% closer than 200mm.
So, it would be 1.5x closer. Something like this (approximately)
01-16-2010, 10:38 AM   #7
Thx for the measurement!
01-16-2010, 10:39 AM   #8
Thx for that site asdf
01-16-2010, 12:34 PM   #9
A general purpose birding lens will never be long enough; there'll always be a hummingbird fighting with a bumblebee just a little bit too far away.
On the other hand I find longer than 300 impossible to hand-hold - I got a 500:6.3 mirror lens figuring it is light enough to hold.
Yes it is light enough, but I'm way too shakey for it.
I think best might be a lightweight 300:2.8 - the speed is important because exposure times must be short for a long lens near dawn and dusk - but I'm guessing I couldn't handle the weight of a 2.8.
All in all I think the DA 55-300 is long enough. The lens is so good at the long end that you can enlarge by a factor of maybe 2, thereby increasing its effective length.
01-16-2010, 12:58 PM   #10
Ash
Community Manager
Ash's Avatar
300mm is a good start, not the optimal focal length but decent enough for the amateur/casual birder.
Getting more serious would see you going for a longer prime like a 400/4 or longer zoom like Sigma's offerings of 50-500 (Bigma), 120-400 or 150-500. Need money an some muscle to cart these around...
01-16-2010, 01:21 PM   #11
xjjohnno's Avatar
The Bigma isn't all that heavy and quite easy to use hand held. The tripod mount is also a convenient hand grip.
While the DA 55-300 does provide excellent results the likelihood you'll want more lens is very likely.
01-16-2010, 02:25 PM   #12
pacerr's Avatar
Coupl'a useful tips
...what will it look like if the shot was taken at 300mm?
Here's a trick I've found useful over time to envision the FOV of tele lenses.
With your hand held at arm's length, a given focal length has an approximate angle of coverage as follows:
90-100mm = fist/entire width including thumb
135mm = four fingers
180-200mm = three fingers
300mm = two fingers
500mm = be verycareful here!
This is easy to 'calibrate' for yourself using a 70-300mm zoom lens.
(And less ostentatious than a beret and film director's view finder/monocular.)
And I'm growin' real fond of a Jobo Gorilla-pod for hand holding long or heavy lenses.
With two legs spread against my chest (even hooked in a pocket) and the third positioned near/over
my shoulder I'm finding it more comfortable and stable than the gun stock type supports.
Works with a Mamiya 645 as well as all my SLR bodies.
H2
01-16-2010, 02:32 PM   #13
QuoteOriginally posted by xjjohnno Quote
Agreed. I have wondered around airshows for 6 hours at a time wjth my 150-500, no problems.
01-16-2010, 04:36 PM   #14
dadipentak's Avatar
Me, too--but a good 300mm + TC combo can be very effective.
01-16-2010, 05:35 PM   #15
Yes...
If you get close enough, have lots of light, and the bird stands still.
Cheers...
200mm, 55-300mm, birds, da, da 55-300mm, k-mount, pentax lens, slr lens
Shooting birds in flight stanislav Pentax Camera and Field Accessories 12 04-11-2010 09:09 AM
First shots w/ the DA* 300mm (bugs and birds mostly) heliphoto Post Your Photos! 19 09-05-2009 08:01 PM
Birds by DA55-300mm dsport Post Your Photos! 17 01-12-2009 11:19 AM
First attempt to birds (Sigma 100-300mm F4) Duh_Vinci Post Your Photos! 13 03-23-2008 06:33 PM
First time shooting birds (9 images) Tyler Post Your Photos! 8 07-25-2007 08:53 AM
All times are GMT -7. The time now is 09:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
