01-16-2010, 12:07 PM   #1
netuser's Avatar
FA* 300mm/2.8 vs DA* 300mm/4, how does it compare?
Apart from the f2.8 vs f4, care to share your opinions/facts between the IQ of this two lenses ???
Thanks
01-16-2010, 08:17 PM   #2
borno's Avatar
My FA*300 f2.8 was not as sharp as my DA300 even at f4 with the DA wide open. It didn't sharpen up even stopped down, but it was obviously not a good copy.
01-16-2010, 08:34 PM   #3
Albert Siegel's Avatar
I did play with both for a few shots today and so far my opinion is this:
I cannot tell them apart in terms of sharpness. If I were to look at 100% for a few minutes, I would say the DA* is 0.2% sharper.. as in you will never notice it in print at any size.
The FA* is cooler or the DA* is warmer for colors depending on how you look at it.
The FA* does love to PF compared to the DA* which has nearly zero that I could see.
In my quick test opinion, so far there is no real advantage to the FA* over the DA* unless you must have the 2.8 as I must. (I work as a photojournalist and product photographer - fulltime working pro)
I will try to compare with photos as soon as I have some time. I will post my results when I do. Today was just a five minute quick look just to get an idea. This is not my final word or opinion.
01-17-2010, 06:23 AM   #4
pcarfan's Avatar
Albert, the difference might be even more for someone wanting to use TC's with theirs, especially the 1.7X or the 2X versions. I wonder whether you believe in TC's, and if so, mind posting some comaprision shots with those.
k-mount, pentax lens, slr lens, vs
DA 55-300mm shoots some pretty decent pseudo-macro shots at 300mm G-Diesel Pentax SLR Lens Discussion 14 10-19-2010 07:47 PM
Pentax DA 55-300mm vs Tamron 70-300mm at long end (brickwall) tcdk Pentax SLR Lens Discussion 17 11-15-2009 12:52 AM
Compare 70-300mm AF lenses Papersniper Pentax SLR Lens Discussion 1 11-06-2007 09:36 AM
All times are GMT -7. The time now is 11:56 AM. | See also: NikonForums.com, part of our network of photo forums!
