06-23-2007, 07:05 AM   #1
Help on a teleconverter for Sigma 135-400mm
What would be the best teleconverter for a Sigma 135-400mm on a K10D?
Would there be any restrictions?
Thanks to All!
06-23-2007, 07:58 AM   #2
Moderator Emeritus
I would recommend a 1.4x converter if you are getting one, Tamron makes a good version as does Sigma (APO EX). Also the Pentax A 1.4x-S or the A 2x-S Both will cost more but produce a little better results. The 1.4's will multiply a 400mm to roughly a 560mm which has an effective focal length of 840mm on a DSLR and you only loose 1 stop (at f4 the lens becomes f5.6 etc). A 2x converter will cost you 2 stops.
You may loose the auto focus though, unless the lens has the drive slot. The Sigma APO and Tamron 1.4's have the drive slot for the auto focus feature. There may be others that have the drive slot as well. AF may slow down as well depending on the available light. You're adding more glass to the back of the lens and cutting down on the light getting to the sensors.
These converters do reduce the lenses image quality as well (some not too bad and others quite a lot). Any converter will show a loss in the final image.
06-24-2007, 07:52 AM   #3
Lowell Goudge's Avatar
QuoteOriginally posted by rdrum76 Quote
Thanks to All!
there is no best TC for the 135-400, although AF might work at the shorter focal lengths, when you zoom out to 400 mm, F5.6 is just too slow for autofocus to work. You will be stuck in manual focus.
06-24-2007, 04:49 PM   #4
Buddha Jones's Avatar
I cant remember if that lens is an APO or not, but Sigma makes TCs for all of their lenses, including APO specific.
06-25-2007, 12:51 AM   #5
Arpe's Avatar
QuoteOriginally posted by Peter Zack Quote
...as does Sigma (APO EX)
Don't those only work with the Sigma EX lenses? (certainly doesn't fit my Pentax 80-320)
k-mount, pentax lens, sigma, slr lens, teleconverter, teleconverter for sigma
For Sale - Sold: SIGMA 135-400mm/4.5-5.6 maxwell1295 Sold Items 3 04-26-2009 05:25 PM
Tokina 80-400mm vs. Sigma 135-400mm Buddha Jones Pentax SLR Lens Discussion 13 02-02-2008 04:53 PM
Sigma APO 135-400mm F4.5-5.6 DG Tyler Pentax SLR Lens Discussion 5 07-14-2007 03:47 PM
All times are GMT -7. The time now is 11:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
