01-19-2010, 09:50 AM   #1
What would i need for this lens?
What adapter would i need for this lens
Asahi Pentax 1:3.5/28 wide angle lens
Someone i know is selling one?
Where would i get the adapter from aswell?
Does anyone have one?
You could create a for sale thread : )
01-19-2010, 10:37 AM   #2
Mechan1k's Avatar
This could either be a K-mount or an M42 lens.
With the Pentax name on it .. I'd say it is a K-mount.
Do you have an image of this lens???
The Takumar range (prior to being branded as Pentax) is pretty much M42 screwmount (apart from the odd few that came in the K-bayonet mount)
01-19-2010, 11:01 AM   #3
GerryL's Avatar
If you had a photo then it would be easier to identify..specially with the photo of the mount end.
01-19-2010, 12:44 PM   #4
Marc Sabatella's Avatar
QuoteOriginally posted by thehitmen Quote
Then simply ask them if the kens is K-mount of M42 screwmount. If they say K, no adapter needed - but read the sticky thread on using manual lenses in the beginner's forum. If they say M42, then you need the screwmount adapter. If they don't know, don't buy the lens, as the fact they don't know what kind of mount it is means they also have no idea if it works.
01-19-2010, 04:09 PM   #5
Hope this helps you
01-19-2010, 04:14 PM   #6
Damn Brit
Guest
That's a M42 screwmount, this is the adapter you need - PentaxWebstore Mount Adapter K(35m m Screwmount to Bayonet)
You can get cheaper, non-Pentax adapters on e-bay but a lot of them don't allow you to focus to infinity.
01-19-2010, 06:43 PM   #7
QuoteOriginally posted by Damn Brit Quote
Cheers for that.
What do you mean, focus to infinity ?
01-19-2010, 06:50 PM   #8
GerryL's Avatar
Cheers for that.
There are flange mount adapters which also do the same job as the M42 adapters (be able to attach the screw mount to "K" camera mount) but it doesn't sit it flush on the camera body since there is a flange. The lens registration would be off by a millimeter or so and when this happens, when the lens is set to focus to the horizon (infinity, the lens has the horizontal figure "8" at the end of the focus ring), you won't get focus on that.
It would only focus to about 50 meters or so but not beyond that.
adapter, k-mount, lens, pentax lens, slr lens
All times are GMT -7. The time now is 03:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
