01-21-2010, 04:51 PM   #1
Uncle_dad's Avatar
16-45mm or 17-70mm
Is the 17-70 a step up in IQ over the 16-45? Or is it more just a sideways step? I want to up grade the kit lens but wonder if its worth the extra 200 dollars for the 17-70. I do like landscapes shots but then that 70mm end sounds good also. Thanks
01-21-2010, 05:05 PM   #2
QuoteOriginally posted by Uncle_dad Quote
17-70 has less chromatic aberration, but 16-45 has less barrel distortion at the wide end. Otherwise, it would be difficult to distinguish images taken by both in their overlapping 17-45 range. 17-70 has a rubber gasket around the mount, but it's not classified as WR. Also, SDM motors do fail (mine did, but was replaced within a week). The AF speed is almost exactly the same on both, but 16-45 is very loud (but this doesn't have to be an issue).
01-21-2010, 06:00 PM   #3
Blue's Avatar
It may depend on whether or not you plan on getting a DA 70mm or FA 77mm ltd later or not. If not, I think it would be worth it.
01-21-2010, 08:10 PM   #4
Third option: Tamron 17-50mm f/2.8.
Razor sharp from wide open, and wide open is a lot wider than with either of the Pentax lenses (and it doesn't have the SDM failure problems of the DA* 16-50mm f/2.8).
01-22-2010, 10:41 AM   #5
Uncle_dad's Avatar
QuoteOriginally posted by deadwolfbones Quote
So Bones do you think the Tamron is as good in the IQ department as the other 2? Thanks for your opinion. And I am not even thinking about the 16-50 due to the SDM issue.
01-22-2010, 10:59 AM   #6
I've owned the 16-45, but not the 17-70 (though I did own the Sigma 17-70 f/2.8-4.5).
I think the Tamron has the best IQ of the ones I've used, and the constant f/2.8 is great for shallow depth of field shooting and indoor/low-light shooting.
You can check out the "Tammy Club" thread here for a lot of examples. Some of mine are here: Football 12-6-09 - deadwolfbones' Photos
01-22-2010, 03:12 PM   #7
Blue's Avatar
Here is a link to Ned Bunnell's blog on the Da 17-70mm lens.
NED BUNNELL: DA 17-70 Sample Photos
Here is another to a blog about the FA 77mm & K-x: NED BUNNELL: Colorado Railroad Musuem
01-24-2010, 02:12 AM   #8
I have the Pentax 17-70 and I'm very satisfied with it, this lens is on my cam 95% of the time. Most of the time I shoot indoors, so I use it almost always wide open and I like its IQ. I mainly use 28-40mm and 60-70mm FL, this is a great lens to cover those without changing lenses.
I don't have 16-45, but I1ve heard it's a great lens, too.
01-24-2010, 02:22 AM   #9
Jasvox's Avatar
Another vote for the Tamron 17-50. I was comparing several lenses when I made my choice for the 17-50, including the 16-45 and the 16-50*. The 17-50 was just simply a brilliant lens and for a very attractive price...not to mention faster than the 16-45. Its a winner, for sure.
Jason
01-24-2010, 03:31 PM   #10
Uncle_dad's Avatar
I'd like to thank everone for the help. After tormenting myself for days i am going with the Tamron 17-50 and hope'n that Prodigital2000 is good place to do business with as I wait for the lens to get here. Thanks again all for take'n the time to answer back !!!!
01-25-2010, 10:52 AM   #11
No problem, hope it works out for you!
k-mount, pentax lens, slr lens, step
16-45mm vs 17-50mm vs 17-70mm bjornzzz Pentax SLR Lens Discussion 16 10-28-2010 02:01 AM
DA 16-45mm vs. DA 17-70mm raymeedc Pentax SLR Lens Discussion 4 05-08-2010 08:25 AM
Sigma 17-70mm vs pentax 16-45mm or OTHER! clipsed Pentax SLR Lens Discussion 8 02-22-2010 07:50 AM
16-45mm or 16-50mm or 17-70mm ? Neducati Pentax SLR Lens Discussion 23 12-08-2008 12:20 PM
sigma DC 17-70mm vs. Pentax DA 16-45mm Edvinas Pentax SLR Lens Discussion 2 11-19-2006 10:48 PM
All times are GMT -7. The time now is 12:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
