Originally posted by Igor123 Hi, this humidity discussion confuses me somewhat. I live in Sweden and at my location we've had about more than 80% humidity for the last months although the temperature has never been above 0c.
I read a bit about different ways of measuring humidity and it turns out that what's usually used, the relative humidity, is indeed a vastly different amount of water per air volume, depending on temperature (and pressure).
So my question is, is it the relative or absolute (or any other) quantity of humidity we are afraid of, and could a "line" be drawn between what's ok and what's not?
Hi Igor!
I also live in Sweden, and I also teach geography including climate, so take my word on this.
Absolute humidity is not very interesting in our case, it's the relative humidity that counts. The % number indicates how much water (in it's gas form, steam) the air contains
compared to how much it can hold. And warmer air can contain more water than cold air. So if you heaten air, without adding water, the air will become relatively dryer. Air so to speak tries to come up to 100%, and will take water where it finds it. Being plant leaves, wet laundry, or lens surfaces.
In our climate the cold outside air can contain very little water (in absolute terms) so it easily comes up to near 100%. Thats why it's a bad idea to hang your laundry outdoors in winter. But when we take this cold, relatively but not absolutely humid air indoors and warm it up, it becomes very dry. That's why pot plants dont' thrive over the radiator under the window sill, and why our lenses thrive perfectly without precaution.
But look out for condensation when you've been out shooting in the cold. Leave the camera and lenses in the bag till they have aquired room temperature, then you can put them in your cupboard, or leave them in the bag.
Kjell
