01-25-2010, 11:15 AM   #1
dugrant153's Avatar
DA14mm F2.8 - soft at F2.8?
Hi all,
Last time I tried the DA14mm at F2.8, I found it to be soft AND the focus never seemed to be dead on.
Is this normal for this lens? I found that I needed to stop down to F4 to get some sharpness throughout the frame. As for the auto-focusing, maybe it's the "wideness" of the lens that makes it sometimes get the focus right? Or did I test a bad copy?
01-25-2010, 11:27 AM   #2
QuoteOriginally posted by dugrant153 Quote
Hi all,
Here's a sample from photozone at f/2.8:
http://www.pzimages.com/8Reviews/lenses/pentax_14_28/samples/IMGP4506_acr37.jpg
BTW, the field curvature of this lens is "wavy."
01-26-2010, 06:42 AM   #3
audiobomber's Avatar
QuoteOriginally posted by asdf Quote
I wonder whether the new lens correction feature in the K-7 and K-x would eliminate this moustache distortion?
01-26-2010, 06:44 AM   #4
QuoteOriginally posted by audiobomber Quote
I'm referring to the area in focus, actually. EDIT: Macro lenses have a flat field curvature which makes them ideal for ISO resolution chart tests, brick walls and cereal boxes. Otherwise, the borders and corners can easily fall out of focus, making such tests unfair.
diglloyd: Understanding field curvature
As for the distortion, there was a thread about this recently...It turns out the cameras don't do a good job removing it, but PTLens does.
01-26-2010, 08:03 AM   #5
My K-x does a great job removing distortion on the DA 18-250mm.
The reason I asked about the DA 14mm is that the distortion is not simple barrel. It goes from barrel to pincushion, so is not easy to correct with PT Lens. I'm wondering what the camera's lens correction can do.
01-26-2010, 08:07 AM   #6
In PTLens, you press "OK" to correct the distortion. Is that "not easy"?
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/87494-super-wi...m-12-24mm.html
01-26-2010, 08:33 AM   #7
I was going by this quote from Photozone: "Distortions are relatively well controlled but quite wavy thus somewhat more difficult to correct via imaging tools." But I guess with PT Lens having lens specific correction it does the job without the trouble. I will definitely have to get PT Lens and see what it does for defishing my 10-17.
01-26-2010, 08:35 AM   #8
That's a damn nice photo.
01-26-2010, 12:49 PM   #9
Lodewijk's Avatar
Some quick answers:
My DA 14 would hunt sometimes when focusing near infinity on the K100DS. Other than that it worked quite fast and ok. On the K-x I have no problem at all.
The K-x in camera lens correction corrects only for the barrel distortion and not for the pincushion distortion it seems.
Regarding sharpness, I recently made a 50x70 cm print of a photo taken at f3.5 with the subject in a corner, and it turned out really well. With proper focusing it is really sharp, more than enough for real world use.
01-26-2010, 01:29 PM   #10
dugrant153's Avatar
ah, maybe the copy I tried out was a bit weird, or I'm not used to such a wide angle field of view.
I think the focusing was the main thing. It just wasn't tack sharp on my K10D. Definitely had BF.
da14mm, da14mm f2.8, f2.8, focus, k-mount, lens, pentax lens, slr lens
The Soft Place: Post Your Soft Focus Images jeffkpotter Mini-Challenges, Games, and Photo Stories 64 04-22-2014 05:39 PM
DA15mm limited vs DA14mm kuau Pentax SLR Lens Discussion 42 05-13-2010 02:17 PM
For Sale - Sold: Pentax DA14mm f2,8 JeffJS Sold Items 7 03-24-2010 10:09 AM
The Soft Place: Post Your Soft Focus Images jeffkpotter Post Your Photos! 22 04-23-2009 09:04 PM
LBA - DA14mm f/2.8 ED (IF) Asad_Masede Post Your Photos! 24 04-17-2007 12:13 PM
All times are GMT -7. The time now is 10:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
