01-28-2010, 12:02 PM   #1
Need genuine M42 K mount adaptor
Hello,
I just ordered a navy K-x that I will be picking up soon. One of the reasons I went with Pentax is that I've recently discovered the joy of finding lenses at my local thrift store. I've picked up a Yashinon dx 50/1.4, a Komine-made Vivitar 135/2.8, and a Pentax smc-m 200/4.
For the first 2 lenses, I will need a M42 adaptor. The Pentax brand are OOS at the Pentax web store, and the ones I've seen on Ebay are going for close to $50.
Anyone know another source?
Thanks!
01-28-2010, 02:35 PM   #2
GoremanX's Avatar
I don't have a "genuine" Pentax adapter. I have some generic adapter. But it works fine. It mounts well, includes the tool to install/remove it, and allows my M42 lenses to focus to infinity. The only difference that I can see is that I paid $10 for it.
So what's wrong with that?
Amazon.com: Fotodiox M42 Lens - Pentax K/PK Mount Camera Adapter for Pentax K-7, K2000D, K200D, K20D, K10D Super, K10D, K110D, K100D, *ist, D, DL, DL2, DS, DS2, Samsung GX-20, GX-10: Camera & Photo
01-28-2010, 02:45 PM   #3
aleonx3's Avatar
I want to find an inexpensive one so I can buy several and keep one each on the lens rather than changing it on the camera. Anybody can recommend one and the source? Thanks...
01-28-2010, 02:58 PM   #4
GoremanX's Avatar
QuoteOriginally posted by aleonx3 Quote
you can't do that. The adapter clips into place using an adapter-mounted spring clip. The only way to retract this spring clip is with the included tool, and the only way to use the tool (or even reach the spring clip) is to remove the lens. The K-mount release button doesn't even do anything, I don't use it to remove the adapter. There's no way around it if you want to be able to focus to infinity, you need a flush-mounted adapter, and those can't use the camera's locking pin to stay in place.
01-28-2010, 03:06 PM   #5
aleonx3's Avatar
I agree, I am still looking.. I remember someone posted some nice m42 lens with an adapter on each one of them... apparently there could be something like that out there.
01-28-2010, 03:27 PM   #6
GoremanX's Avatar
There are two types of adapters. The flush-mount ones (which allow focus to infinity) and the flanged ones (which do not). The flanged ones use the K-mount locking pin to lock into place, because the flange goes right over that pin. So those can be left on the lens. But at the loss of infinity focusing.
01-28-2010, 09:37 PM   #7
Spring clip isn't necessary
QuoteOriginally posted by GoremanX Quote
Not true.
I only have one adapter (third party generic one), but then I only have one M42 lens that I use; my 50mm, f/1.4 from my Spotmatic. My adapter is not a genuine Pentax, but it is the type that fits flush inside the camera lens mount and allows infinity focus.
The spring clip fell off of mine, but I have heard of many people who removed them deliberately. Now, the adapter stays on the lens. In use, I use the lens as if it were a k-mount lens. Friction is more than enough to keep the lens in place, so I don't miss the clip at all.
I have even heard of people drilling a small hole in the lens base, to match up to the lens lock pin on the camera. I haven't done that and I've never felt that the lens was in danger of falling off the camera.
Its also less of a PITA to have to screw the adapter onto the lens before mounting, but unscrew the lens from the adapter when removing. Like I said, my 50mm is now effectively a k-mount lens.
01-28-2010, 09:43 PM   #8
GoremanX's Avatar
QuoteOriginally posted by noblepa Quote
Well sure, if you break the adapter, then you can do that I was actually considering doing that myself for my Super Takumar 50mm f1.4. It seems like the adapter holds on more than tight enough with just friction. All I'd need is a dab of threadlocker compound on the threads of the lens. But I'd never recommend that someone purposely break their adapter and put threadlocker on their vintage lens.
01-28-2010, 09:48 PM   #9
boriscleto's Avatar
Just keep looking on eBay for a genuine adapter. I got mine a couple of weeks ago for $19.
01-28-2010, 10:48 PM   #10
Thank you for all the info! I have heard that an genuaine Pentax adapter is the way to go for ease of use and best results.
I plan to use one on several lenses. I will have to get it off Ebay it looks like.
01-28-2010, 11:32 PM   #11
Damn Brit
Guest
Moved to lens forum
01-29-2010, 11:40 AM   #12
Just1MoreDave's Avatar
The thread lock is not necessary. Ordinary friction works for me, except for one lens that has a high focus effort. I am just avoiding regreasing that lens.
01-29-2010, 12:07 PM   #13
fccwpe's Avatar
I have four M42 lenses each with the "infinity focus" $5 adapters from e-bay (various vendors). I removed the spring and screw with a small jewelers screwdriver. Even though the lens will never "click" into place they are all tight and won't fall off, even a Lentar 400mm that is quite heavy. I have heard stories of people losing their lenses by doing this, but I have had no problems yet.
The only problem I have had is with the spring attached. I could NOT get it off the camera with the supplied tool and had to pry it out with a screwdriver and hope that I had not damaged anything. My advice is to take the spring out of the adapter and make sure the lens is snug when it is attached to the camera. Don't bother with keeping the spring attached and taking your chances with the removal tool.
adaptor, k-mount, lenses, m42, pentax, pentax lens, slr lens, store
Genuine m42 mount adaptor back in stock wshi Pentax Camera and Field Accessories 21 03-06-2010 07:48 AM
For Sale - Sold: Genuine Pentax Mount Adapter K (M42 to K-mount) zx-m Sold Items 6 01-30-2009 01:22 AM
Genuine m42 Adaptor/ K10d kev.pride Pentax SLR Lens Discussion 2 11-24-2008 06:16 AM
M42 to K mount adaptor eccs19 Photographic Technique 1 10-07-2008 04:14 PM
M42 to K Mount adaptor pentaxk100d Pentax Film SLR Discussion 5 03-11-2008 06:27 PM
All times are GMT -7. The time now is 05:10 AM. | See also: NikonForums.com, part of our network of photo forums!
