01-31-2010, 04:42 AM   #1
emr
Guest
Best kit lens replacement without SDM?
It seems that the DA* 16-50mm may well be the optically best kit zoom replacement. However, the current perceived state of SDM - no matter how wide-spread the problem really is after all - makes me want to definitely avoid SDM lenses for now. So, what is the optically best alternative in K mount and with AF?
Tamron SP AF 17-50mm F/2.8 Di II?
Pentax DA 16-45mm?
01-31-2010, 04:52 AM   #2
axl
Tamron 17-50 and DA16-45 have very strong following. So does Sigma 18-50/2.8 The original (non macro) version. I've read a lot of praise on it.
So those three are direct replacements IMO.
If you don't mind getting 2 lenses (Ultra wide - moderate wide & moderate wide - short tele)
Then Sigmas 10-20 + 24-60/70 or Tamrons 10-24 + 28-75 do seem very viable options.
BR
Peter
01-31-2010, 04:55 AM   #3
Zav
Zav's Avatar
DA*16-50 has both SDM af and screw drive af. If SDM fails... then use the screw drive AF
01-31-2010, 04:57 AM   #4
You would also be losing weather sealing (maybe it's not important to you though).
01-31-2010, 05:05 AM   #5
emr
Guest
QuoteOriginally posted by Zav Quote
But I thought that's not possible with the newer camera bodies? Unless one fries the connectors as Peter Zack did accidentally.
01-31-2010, 06:17 AM   #6
Sigma 17-70, Tamron 17-50 and the DA16-45 are all good replacements for the standard lens.
I have used the Sigma 17-70/2.8-4.5 a lot and liked it very much. Recently purchased the DA 16-45/4.0 and the 16 mm is very nice to have. So i guess it depends on your preferences and in general I think that the standard lens is quite good. So if you decide to purchase another lens then take a look at the benefits of those lenses. F2.8 for the Tamron or more wide angle for the DA 16-45.
If you want a very sharp lens at F2.8 you might even consider the Tamron 28-75/2.8. Still is one of my favorites.
Best regards,
Jan Rinze.
01-31-2010, 06:50 AM   #7
I chose the Tamron, but really much prefer a good prime. A20 or 24...FA28 or 35, and all of the LTD lenses suit me much better than any zoom.
01-31-2010, 08:37 AM   #8
flash1100's Avatar
Of the lenses I have owned
Tamron 28-75/2.8
Pentax DA16-45/4
Would also include
Tamron 17-50/2.8
Sigma 17-70 2.8-4
01-31-2010, 12:04 PM   #9
QuoteOriginally posted by emr Quote
That's right emr. Which is why I chose the Pentax DA 16-45. I am very happy with it.
02-09-2010, 01:24 PM   #10
To flash1100
You have owned both DA 16-45mm and Tammy 28-75mm. Which one did you prefer in terms IQ and color rendition? Thanks
02-28-2010, 11:15 AM   #11
germar's Avatar
Is there a published "hack" to cover connector(s) so that SDM fails over to screw drive?
af, k-mount, kit, pentax lens, replacement, sdm, slr lens
Best replacement kit lens for K-X Eagle_Friends Pentax SLR Lens Discussion 3 02-21-2010 10:58 AM
Replacement Kit Lens - 16-45/4 or 20-40/2.8 inneyeseakay Pentax SLR Lens Discussion 0 11-16-2009 07:15 AM
replacement lens kit mec17 Pentax SLR Lens Discussion 6 11-12-2009 12:50 AM
Kit lens replacement (yet again) dws1117 Pentax SLR Lens Discussion 6 10-20-2008 04:22 PM
Kit lens replacement Von Ryan Pentax SLR Lens Discussion 10 10-01-2008 11:33 PM
All times are GMT -7. The time now is 10:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
