Thanks everyone for the awesome advice!
So the TC is definetly going to stay home. Still undecided on the DA10-17, I do like the fisheye effect but I'm afraid it would probably just be a novelty.
I'm also packing my video camera, Panasonic HDC-SD20 full HD handycam. I just wish I could afford a decent wide angle lens for it... (nothing under a thousand bucks that doesn't butcher the HD quality level)
Dave ... Yes, I will have my netbook which has a card reader to download photos daily... I don't trust my memories to a handful of cards! I want daily backups.
allill ... You make a strond point for the 10-17mm my friend!
(ahhh LBA is pulling me in!)
Blue ... The 55-300 is not a great low-light contender on its own, with the TC I only use it in bright sunlight. I'm guessing this lens will only be used for outdoor shots.
Big G ... I'll admit I do like the fish eye effect. The only thing is that I am not sure if it's only a passing novelty for me... time will tell... LBA is doing it's job on me...
bdery ... I'm hoping my 17-50 f2.8 is fast enough, inside the ship I'll probably be using my flash + diffuser. I am thinking of bringing the M50 1.7 anyways just to have a fast 50.
BrianK ... You are confirming what I was suspecting (17-50 + 55-300). I will have my W60 (in a case on my belt at all times) as point and shoot, and plan on using my Lowe Slingshot 100 for the whole trip.
alfdog ... Yes, I do have a polarizer for my Tamron and forgot to mention I would bring it. It also has a step down ring so I can use it on my DA55-300. There is a difference between a vacation and a photo trip???
jibbonpoint ... I'll admit the wide angle tempts me because I've been told it's pretty cramped inside a ship, and some of the ports we'll visit will surely have some achitecture worthy of wide shots.
Marc ... I am indeed comfortable with the flash, but if I were to get the 10-17 should I be concerned with it's coverage? I plan on using it's built in diffuser + a set of
diffuser/reflectors I made from thin cutting boards.
Parallax ... You are right, this is the IDEAL excuse for LBA
ivoire ... I have to admit I'm not much of a fan od the 40mm, but if I had extra $$$ lying around I'd be getting the FA31
Ah elusive money, where are thou!
I did check out the Rokinon, but here in Canada it's a ripoff.
Thanks folks! Ahhh decisions decisions!
Pat
