02-02-2010, 05:27 AM   #1
Differences between various 18-55mm's?
Anyone give me a quick run down on the differences between these 18-55's (DA AL, DA AL II, DA L)
From what I can find I think the DA L doesn't have 'quick shift', but do the others have it? Can't find confirmation of that.
Any other suggestions for a 'don't care if it gets stolen' lens? (not a Sigma either... see below) Needs to be a wideish zoomy (18-?) that fits into a snout case on my K10D. I have a 16-45 but that won't fit and I bought a 18-35 Sigma but that won't fit due to a very wide filter ring (Didn't do my research on that!) Don't like the build quality of the Sigma either (I'll be moving that on again).
Cheers, Nige
02-02-2010, 05:33 AM   #2
This should be in lens discussion section.
02-02-2010, 06:06 AM   #3
Jasvox's Avatar
Yes, in lens section...
about a lens you are asking for...why not the 18-55 kit lens? You can get them for next to nothing anyway.
Jason
02-02-2010, 07:22 AM   #4
blackcloudbrew's Avatar
Doing this from memory, here is what I recall.
The DA 18-55 was the first DA kit lens. (I have two of them.)
They brought out the DA 18-55 II around the time the K20d was released because apparently the optics weren't quite up to the quality of the K20 sensor or so the story went.
The DA L 18-55 was released with the K-m or K-2000 as a light weight version of the DA 18-55 (I don't know if it was the II version or not) and yes it was missing the quick shift ring.
With the release of the K-7 they released the DA 18-55 WR (weather resistant) version which I believe was based on the II version.
Hope that helps.
02-02-2010, 11:38 AM   #5
QuoteOriginally posted by blackcloudbrew Quote
Plus the K-x kit lens has a plastic mount and I think it came without a lens hood.
02-02-2010, 01:04 PM   #6
Marc Sabatella's Avatar
The original 18-55 used an older and not quite as good optical formula, all the others (II, WR, and L) use the newer improved one. Of the latter three, WR is a step up because it is weather sealed, and L a step down because it lacks quickshift (as well as a hood, and it has a plastic mount).
This is such an FAQ that I'm thinking I should make this a sticky thread - and move it to either the beginners or lens forum. Opinions?
02-02-2010, 01:56 PM   #7
The differences between these lens is something I've wondered about recently, being new to Pentax DSLRs and not knowing one from the other. I can only assume other new users would also wonder.
I just hope the optics in the L series aren't inferior to the other Pentax series since there is a new K-x on its way to me.
02-02-2010, 03:17 PM   #8
er1kksen's Avatar
I've owned a II version and I've owned an L version. The L version has been rather unsatisfying, optically speaking. I usually use it stopped down to at least f7.1 regardless of focal length. The II was pretty usable even wide open (on a higher-res body, no less). However, given that this is simultaneously Pentax's cheapest and most mass-produced lens line, I would suspect that sample variation may play a bigger role here than actual differences in optical design.
02-02-2010, 03:46 PM   #9
QuoteOriginally posted by er1kksen Quote
I think sample variation is the key. I have the 18-55 L that came with my Kx, and my quick tests reveal it to be reasonably good even wide open. Not great compared to my primes of course, but good.
02-02-2010, 03:49 PM   #10
QuoteOriginally posted by Jasvox Quote
I'm sure that's where I posted it... I had to search my own threads to find this this morning!
Jason
unfortunately not "next-to-nothing" here. Local Cash-Convertors has one (not sure what derivation, for AUD$229... thats about US$200). Can get one (new) for about $150 from Hong Kong but was wanting something a lot cheaper as the chances of it getting stolen (along with my old K10D is high). A 'kit' that I can get locally for US prices would be my preference. Could have bid on a Sigma 18-50 last night (went for $40) but after playing with the Sigma 18-35 decided against it. Buying one for about US$50 from here would be good if I could be guaranteed it would get here in less than 4 weeks, but without paying high postage that's not a certainty. Might just end up leaving dSLR at home and making do with the Mrs's p&s.
QuoteOriginally posted by blackcloudbrew:
Hope that helps.
Certainly does, looks like I should chase a 'II', although I won't go past either of the others if they pop up.
Cheers, Nige
02-08-2010, 09:16 PM   #11
Finn's Avatar
I think that has a lot to do with it. I've had 2 first-gen DA 18-55's and now have the DA L 18-55, and the DA L is definitely the sharpest of the bunch. It's all a roll of the dice.
02-17-2010, 07:34 PM   #12
ramseybuckeye's Avatar
I bought my K20D without a kit lens last year but recently aquired an AL. Having read mostly unflattering things about the kits, I was very pleasantly surprised. I'm very happy with it, it seems faster than it should. Sorry, can't compare to the others I haven't used.
02-17-2010, 08:37 PM   #13
MoiVous's Avatar
Just to add a little more to the L vs AL II information - including links:
There is also a nice comparison between the AL and AL II at Lens Tip
Cheers
Last edited by MoiVous; 02-17-2010 at 10:53 PM. Reason: Updated AL details & Lens Tip review
02-19-2010, 10:29 PM   #14
I have the AL, mine has the hood pop out too.
02-25-2010, 12:22 AM   #15
Blue's Avatar
The original 18-55mm AL had an optical formula of 12/9 (although the diagram at dimitrov's site looks like 13/9 to me).
The 18-55mm AL II has a formula of 11/8 as does the WR and the L version. In addition the WR version has the SP coating (Super-Protect). As mentioned, the L lacks the quick shift and has a plastic mount.
Edit: Here are the diagrams from dimitrov and you can see what I mean about it looking like 13 elements there.
AL
AL II (also the WR and L versions)
http://kmp.bdimitrov.de/lenses/zooms/short/index.html
da, k-mount, pentax lens, sigma, slr lens
Help me see the differences Aanund Pentax SLR Lens Discussion 11 04-09-2010 01:54 AM
Big price differences on 18-55mm lens Frankie500 Troubleshooting and Beginner Help 5 09-13-2009 06:28 PM
K-7/K20 IQ differences? MJB DIGITAL Pentax DSLR Discussion 26 08-15-2009 05:37 PM
Differences? Mallee Boy Photo Critique 2 11-02-2007 10:14 PM
Z-1/PZ-1 vs. Z-1p/PZ-1p - differences? scottax1 Pentax Film SLR Discussion 5 08-27-2007 03:01 AM
All times are GMT -7. The time now is 09:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
