02-03-2010, 02:44 AM   #1
tokina 10-17mm or 12-24mm?
Hi all
Do they make these for Pentax?? I can only find them for cannon and nikon.......there doesnt seem to be any in the reviews either?
I am after a wide lens........am I restricted to sigma or tamron? The pentax will be out of my price range a nice policeman said I needed new tyres first
cheers
Jan
02-03-2010, 03:05 AM   #2
Pentax Lens Review and Specification Database - 10-17mm F3.5-4.5 Fish-Eye ED [IF]
Pentax Lens Review and Specification Database - 12-24mm F4 ED AL [IF]
Just the Pentax ones.
02-03-2010, 03:24 AM   #3
Ben_Edict's Avatar
QuoteOriginally posted by ricstew Quote
Hi all
cheers
Jan
You have to buy these lenses from Pentax. Both lenses are a joint effort by Pentax and Tokina and part of the deal seems to be, that Tokina sells only for other mounts and Pentax exclusively for K-mount.
Ben
02-03-2010, 03:50 AM   #4
jeeeez I must be blind! I am sorry I missed those reviews........now if I can just work out where to purchase in Oz.........would they be listed under pentax or tokina?
cheers
Jan
02-03-2010, 05:05 AM   #5
it will be listed under pentax. The typical retail price for these 2 lens should be around 799 and 1199.
There is a samsung equivalent pf 10-17 in ebay now only for <AUD600.
02-03-2010, 08:31 AM   #6
Ben_Edict's Avatar
cheers
Jan
Only Pentax. it is the brand. Tokina does not make these lenses in Pentax mount.
Ben
02-03-2010, 02:53 PM   #7
maximm's Avatar
Im thinking about switching from the 10-17 to the 12-24. Does anyone have any comparision pictures i could lay my eyes on?
02-03-2010, 04:31 PM   #8
Pentaxor's Avatar
QuoteOriginally posted by maximm Quote
it's just like the 18-55 but with more FOV coverage, much better sharpness and contrast and less distortion at wide open. hope that helps.
02-03-2010, 10:35 PM   #9
Evening, I have an older post that compares 3 lenses including both the 12-24 and the 10-17 FE in approximately the same picture. Its at night, so the fish eye (FE) distortion is not as apparent.
https://www.pentaxforums.com/forums/general-photography-techniques-styles/834...panoramas.html
I do have to admit for your needs, this is somewhat of an unfair comparison. I was comparing the relative detail obtained with each lens in a stitched panorama use. All the lenses were in a portrait mode, with the exception of the 10-17FE.
To understand the FE effect in an image you really need to have some images done in the day light.
The 12-24 is extremely sharp, and I find the distortion at the edges well controlled. dpreview had a comparison and found it sharper than the Pentax DA15 Limited. Bottom line is - it is a very good lens. The field of view is 100 to 60 degrees.
The 10-17 FE is a fish eye. Its field of view is 180 degrees to 100 degrees. So in regard to the FOV the two lens complement each other, and do not overlap as their focal lengths might indicate. The 10-17 is somewhat of a specialty lens. It does have an pronounced fish eyed effect at 10mm, decreasing to a pretty well controlled FE effect at 17mm. At 17 it does appear to take on characteristics of a rectilinear lens - however the FE effect is still there. You can defish the images with post processing software.
02-05-2010, 01:45 AM   #10
Thanks guys
I have been away........
I am pretty sure I will go with the sigma 12 -24.....the reviews are very favourable.........and I would prefer less of the fish eye effect if I can get away with it.
cheers
Jan
k-mount, pentax lens, slr lens
Do You Use your 10-17mm MORE Than your 12-24mm??? Ron_Man Pentax SLR Lens Discussion 4 07-20-2010 06:19 PM
Tokina RMC 17mm F3.5 Lens eagle7312 Photographic Technique 4 03-24-2008 08:35 PM
Tokina 17mm f3.5 RMC -spam- Pentax SLR Lens Discussion 4 10-23-2007 09:45 AM
For Sale - Sold: FS: Tokina 17mm, Tokina 100-300mm, Sigma 28-200mm time-snaps Sold Items 2 07-24-2007 03:47 PM
All times are GMT -7. The time now is 08:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
