Those adapters (Pentacon Six to K-mount) are well made, at least from what i see from the pictures, and with a finishing that is probably better than a custom-made adapter produced by a very good photographic mechanic (spending at least five time more money, i suppose... if you could find somebody with enough spare time, and crazy enough to work it at the lathe piece by piece!).
They even make a tilt/shift adapter, that is a very nice work of mechanics!
Unfortunately those adapters are sold with a standard lens that is not useful with a digital camera. Even with a full frame camera a 80mm has a focal that is too long for most architecture applications. The tilt movement is useful when you shoot with a wide angle, from close to the subject. With an 80mm, that becomes a 120mm with an APS-C sensor, you are allowed to shoot from a certain distance, so you're very likely to find an elevated place, from where you could shoot a picture that is mostly free of prospectic distorsions.
With an 80mm lens it would be more appropriate to use the tilt movement, if you shoot still-life and macro.
Unfortunately i couldn't find a tilt/shift adapter with no lens fitted, at least on Ebay, so there is no chance to reverse the original lens or use another one.
The tilt OR shift adapters could be a little more useful, in particular the shift adapter has a lot of appeal, because i love to take pictures of urban landscapes, but after all the researches that i've made, i couldn't find a solution that made me actually but the adapter.
I have no use for the tilt adapter (i have some bigger cameras that do it, albeit only with film), but i would be more than happy to get the tilt adapter if only i could find a Pentacon Six lens with a focal short enough to be of some use in the field.
The shorter wide angle available is a 45mm, too much, if you consider that it would become a 70mm ca. with a digital camera. At least years ago those lenses were quite easy to find, but now the price got up, and now finding a good, recent lens, with multicoating, is not so easy anymore.
There is a very nice 30mm f2.8 made in Ukraina, and still available (like) new. But that lens is a fisheye!
I even own one, cause i wanted to adapt it to a Pentax 6x7, as i have done with other P-6 lenses, but i discovered that it would cost too much, cause a radical rework of the lens is needed.
The coverage is OK to allow shifting, the FL is not so OK, but acceptable in some situations, but i am afraid that the amount of uncorrected distorsion, typical of a fisheye, would still be noticeable even if the digital sensor gets only the central part of the image.
If you have to correct barrel distorsion in Photoshop, then you could do the same with prospectic distorsion, without spending a single cent!
I am not an expert of optics, and i have no chance to be able to borrow an adapter, fit the 30mm on it, and make a few pictures with the lens fully shifted.
So i'm asking if somebody did a similar experiment, or has enough scientific preparation to be able to guess what could be the result.
have fun
CJ
