02-05-2010, 02:24 PM   #1
old lenses for using with a K7 - advice please
Hi, I need some wise heads to give me some advice. I am planning to buy a K7 and have some old SLR lenses that I need to know whether they are worth using with the new DSLR. They are as follows:
SMC Pentax - M 1:2.8 28mm
SMC Pentax - A Zoom 1:3.5 ~ 4.5 35 ~ 70mm
Sigma Zoom - f 60-200mm 1: 4 ~ 5.6
Kiron 80 - 200mm f / 4 Macro 1:4
I guess thatn the two Pentax lenses are probably worth using but not sure about the other two.
If anyone has advice about what new DSLR lenses i should get with the K7 that would be great. Please bear in mind that I might struggle with tech speak so plain english would be helpful
Cheers H
02-05-2010, 02:30 PM   #2
bdery's Avatar
Hello!
The 28 is a great lens, and will give you a nearly normal FOV with the K7. The Pentax- is ok but the 18-55 kit lens provided with the K7 will be better (with autofocus, and it will be weatherproof). the Kiron zoom ought to be ok, the Sigma zoom les so.
One thing to remember is that these lenses will be, generally speaking, just as good with a K7 as they were with a film camera. No surprises, no real changes, they are the same lenses.
The lenses could be a good starting point to evaluate which focal lengths you enjoy using the most. Then if necessary you can adapt your kit.
advice, dslr, k-mount, k7, lenses, pentax, pentax lens, slr lens, smc
Going on vacation and need advice on lenses akira181 Pentax SLR Lens Discussion 15 10-02-2009 07:02 AM
Advice on lenses. rinoaa52r Pentax SLR Lens Discussion 4 08-05-2009 02:47 PM
Hello! Need some advice for buying lenses. Tiu Pentax SLR Lens Discussion 7 07-13-2009 05:40 AM
Advice on T2 adapters and lenses? emr Pentax SLR Lens Discussion 2 03-21-2009 03:51 PM
Advice on lenses zplus Pentax SLR Lens Discussion 6 02-24-2009 06:07 PM
All times are GMT -7. The time now is 01:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
