02-16-2010, 11:50 AM   #16
aliasant's Avatar
QuoteOriginally posted by Vilkvaale Quote
This is how my Vivitar lens looks like. Is it necessary to cut something of?
As Just1MoreDave said you can try to unscrew the dark grey inner ring thing.
It works without it and that is what hinders it from attaching to the house proper.
Your image is so small I cant really see but in my case there was just 2 small screws to remove and then lift that grey/black aluminum ring of.
Maybe it is easier to damage the lens/camera without that ring? Maybe not.
I prefer to still have it, just in case, even if I had to spend 5 minutes modifying it.
02-16-2010, 11:38 PM   #17
QuoteOriginally posted by aliasant Quote
You are right, there are two small screws. I`ll try just unscrew it instead of surgery. Thank you very much for your help guys
02-17-2010, 12:48 AM   #18
aliasant's Avatar
Report back if you can. Curious to see if it worked out ok for you.
02-17-2010, 01:10 AM   #19
why are you removing it? I have an old Vivitar 75-300 with the same aperture lever protector, it works just fine as is.
although the optical quality is really bad (soft and very low contrast).
02-17-2010, 02:33 AM   #20
aliasant's Avatar
QuoteOriginally posted by RolloR Quote
It wont fit to his DSLR as is. The rim ( Grey inner ring thing) is to big/high
02-17-2010, 05:01 AM   #21
It`s strange that lenses produced for Pentax, doesn`t fit Pentax....
02-17-2010, 05:48 AM   #22
Those lenses were made for Pentax film cameras. The DSLR's are built different in the mirror box area. Third party film camera lenses are not guaranteed to fit, only Pentax lenses are.
02-17-2010, 11:51 PM   #23
So I did it. But I was able to unscrew only one screw, other was stucked. So I did bad thing I just pulled the dark grey ring off and second screw is still there. Now my lens fits good to my K-x Thank you very much guys for help and advices
Now I have to learn to work with manual focus, arrgh
02-17-2010, 11:52 PM   #24
QuoteOriginally posted by wildlifephotog Quote
Thanks wildlifephotog. That explains, now it`s clear for me.
k-mount, kx, macro, p/k, pentax lens, slr lens, tele, vivitar
Effects of adapting lens? smcook99 Pentax SLR Lens Discussion 25 04-10-2010 09:09 AM
Adapting Pentax K mount to EOS Psynema Pentax SLR Lens Discussion 5 07-10-2009 12:33 PM
Adapting jimrodman Pentax DSLR Discussion 6 05-09-2008 08:50 AM
adapting a minolta lens to the K10D grindel Pentax SLR Lens Discussion 7 02-03-2008 11:07 AM
All times are GMT -7. The time now is 03:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
