02-12-2010, 10:32 PM   #1
Macro Takumar f/4 50mm
Hi all, I just recently acquired this lens and although it seems a bit worse for wear, everything seems to function fine as far as my newbie eyes can tell.
The focus is solid but feels a touch dry as does the aperture preview ring. The aperture select ring clicks solidly for each setting, although both rings feel a little loose, especially the preview lever ring which can be pulled outward and turned freely.
There's also a fair bit of dust and the filter end of the barrel does seem a bit dinged up. I'm not looking for a museum piece as long as it works and lasts. From the searching I did, I love the images it produces.
Is it salvageable? I read that it can be a relatively simple fix to tighten so I want to attempt it myself but if it's not too expensive, I'd probably feel safer shipping it to a qualified hand.
Here are a few pics:
02-12-2010, 11:04 PM   #2
You have the older super tak version. It will focus down to 1:1! Not too many 50mm lenses do that.
The lens is a preset lens. The behavior of the lens aperture sounds functional.
The lens has been opened before. Is all that dust on the inside or outside?
02-13-2010, 12:02 AM   #3
Yes, I was pretty excited to be in possession of a rather uncommon lens which is why I want to keep it. How can you tell it's been opened before?
I can't tell if the dust is inside or out, but there seems to be a fair bit outside.
Even the shot of the back you can see lots of dust in that large crevice. I'll wipe it down with a microfiber cloth when I find one and take a closer look.
Are you familiar with it's disassembly?
02-13-2010, 12:22 AM   #4
QuoteOriginally posted by lmd91343 Quote
Only the preset Macro-Takumar goes to 1:1 without extension tube. The Super Macro-Takumar and Super-Multi-Coated Takumars only go to 1:2 without extension tube.
From the photos posted to me the lens doesn't look like it has been opened.
The preset Macro-Takumar is one of my favorite lenses!
@Asudef, I'm interested in the procedure you found to tighten; could you post a link? I've worked on several of the other Takumars, mostly the 50, 55, & telephotos; they are relatively simple construction and relatively easy to work on, but I too would hesitate with the macro lenses, unless those instructions are simple and straightforward. I imagine the double helical is complicated.
02-13-2010, 12:47 AM   #5
It wasn't really a procedure but rather just a short blurb about how he revived the lens.
Found here
The aperture preview rotates part of the barrel underneath so it looks like the inner part with the lettering just unscrews off. You can see the separation in the pic.
02-13-2010, 01:27 AM   #6
The flickr photos are currently unavailable...
Yep it's a real simple fix if nothing is missing or broken. I just removed the name plate on mine using only finger pressure inside to unscrew it from the lens body. The remaining piece of the "inner hood" lifts out revealing the screws that hold the preset rings in place -- those are probably loose on your lens; here's hoping they are not missing! Let me know if you want pics...
02-13-2010, 01:37 AM   #7
That would be great if you could show me some pics. I tried turning it by hand with no success, I might have to make some device to grab on the inside and unscrew it.
02-13-2010, 01:44 AM   #8
old-fashioned rubber sink drain stoppers work great; available at local hardware store...I'll post some pics tomorrow morning...
02-13-2010, 02:12 AM   #9
I will have to try that. Thanks for the suggestion!
02-13-2010, 03:34 PM   #10
pics attached
02-13-2010, 11:21 PM   #11
QuoteOriginally posted by Asudef Quote
I don't know how to take it apart, even though I have one. Sorry.
It looks as if the tightening side of the slots appear "bright" on the rear outermost retaining ring. It is a bit out of focus.
02-18-2010, 04:47 AM   #12
Hey, thanks for the pics rhodspin. Your lens looks so pretty unlike mine.
I'm still not able to get the trim ring off, I've tried my fingers, tape and using a divider in the milled out letters to unscrew but it won't seem to budge. Still haven't been able to find a drain stopper but hopefully that's the key.
Maybe some other people have better suggestions?
Btw lmd, you're right they do look bright/used. Can you enlighten me as to what that tightens?
02-18-2010, 09:37 AM   #13
drainplug or a latex glove-covered drinking glass the right size. a little WD-40 or wintergreen oil (pharmacy) sprayed on a q-tip rubbed between ring & body, not too much, give it time to work, some hours or a day or two.
02-17-2012, 07:45 AM   #14
margriet's Avatar
hello guys,
Ive just registered and instead of making some thread in introductions (I might still do that later) I want to thank you all for the tips given in this thread! Super, I would have never thought Id be brave enough to open up a lens.. Yesterday got myself a collection of takumars actually mostly because I really really wanted to have this 50mm macro 1:1 preset. Of course from 50 years ? somethings you can expect to be wobbly a bit, but mine had a 5mm + gap between the two aperture rings. I found the screws completely loosened but still there (pfffoeey). After following the instructions here now no wobbles (maybe a 0.1mm wobble sideways, but hey? no complains there). Especially useful tip this "drain-plug rubber glove tip" ! Never would have imagined a drain-plug could be used for something not annoying.
So thanks! I hope people still read this or new people can learn from this
macro takumar opened by margriet.l,
aperture, bit, k-mount, pentax lens, preview, slr lens
Macro-Takumar 50mm f4 (native 1:1 magnification) arpaagent Pentax SLR Lens Discussion 45 04-25-2010 11:56 AM
m42 smc takumar 50mm macro slow2focus Pentax SLR Lens Discussion 3 12-17-2009 04:55 PM
For Sale - Sold: SMC Macro Takumar 50mm/F4 maxwell1295 Sold Items 8 09-15-2009 09:29 PM
For Sale - Sold: Super Macro Takumar 50mm, Super Takumar 200mm, F 35-80mm Lenses Nick Siebers Sold Items 4 02-01-2009 08:56 PM
For Sale - Sold: Super-macro-takumar 50mm f4 qqspm Sold Items 6 10-30-2008 01:22 PM
All times are GMT -7. The time now is 01:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
