02-18-2010, 11:19 AM   #1
Used lenses, Dust ok?
I'm looking at a used 100mm 2.8 macro pentax smcp-d lens it says;
"Glass is clean with no fungus or scratch. Might have some dust inside, which does not affect final photo. Body is clean. No visible deep scratch."
Does this sound right ... can the dust be cleaned out somehow via repair if it affectes image quality. Do allot of used lenses have dust inside them?
02-18-2010, 11:39 AM   #2
Ed n Georgia's Avatar
QuoteOriginally posted by cannabiscurescancer Quote
Dust inside the lens should make absolutely no difference in the IQ of the lens. Even small scratches won't make a difference.
Take a look a this....
http://www.lensrentals.com/news/2008.10.30/front-element-scratches
02-18-2010, 11:41 AM   #3
Just1MoreDave's Avatar
Most lenses will have some dust inside. It's easy to see but not a big problem. It can be cleaned, but it's not that easy to avoid introducing more dust in the process.
Here's a dust demonstration I did for someone else. The first photo has a clean lens, f8, about 50mm, tripod, 2s delay, ISO200:
Some "dust" on the front element:
Some "dust" on the rear element - I had to unmount the lens for this, so the photos don't quite line up:
Now let's see how much dust that was. The front element "dust", a dot of paper cut from a Post-it note:
The same dot applied to the rear element:
Comparing the full-size images, I can easily see the contrast is reduced, with maybe some color tint. The dot takes up a considerable percentage of the rear element, and the effect is more obvious. I have never seen a lens with that much internal dust.
02-18-2010, 11:48 AM   #4
Igilligan
Guest
Hey Dave
I would love to see that same test at F18-22 ish... on the rear element especially
I have a macro lens with dust on inside of the rear element. If I am trying to stop way down for DOF in my macro shots I can definately see some effects at in the macro shots especially if I crop.
do you still have your test dot?
02-18-2010, 12:05 PM   #5
emr
Guest
There's also an interesting article about how much "dust" a lens can have before it really starts showing. The "dust" in this case is on the external surface, but quite eye-opening anyhow.
Dirty lens article
dust, k-mount, lenses, pentax lens, slr lens
Pentax K-7 Dust Alert and Dust Removal Functions brosen Pentax DSLR Discussion 9 02-09-2016 04:43 AM
DA WR lenses dust magnets? future_retro Pentax SLR Lens Discussion 6 07-17-2010 09:32 PM
Limited Lenses like dust a lot. LFLee Pentax SLR Lens Discussion 1 06-20-2010 02:53 PM
Blowing dust. Will I get more dust inside ? alphalt Pentax DSLR Discussion 7 05-12-2010 10:09 PM
I hate to ask. I have a couple of screw mount lenses gathering dust. magnum1 Pentax SLR Lens Discussion 10 01-15-2009 08:56 AM
All times are GMT -7. The time now is 05:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
